rangerdanger
- Joined
- Oct 9, 2018
- Threads
- 194
- Messages
- 3,487
- Reaction score
- 2,671
- Location
- SF Bay Area
- Vehicle(s)
- 2019 Ford Ranger SuperCrew XLT FX4
- Vehicle Showcase
- 1
- Thread starter
- #1
Since the 2019 Ford Ranger is in the first model year of production, it was bound to have growing pains. To help new and prospective owners, lets assemble a list of problems and whether a solution currently exists.
This is a wiki-post that can be edited by any member.
Transmission Issues:
Engine Issues:
Engine Issues:
- SOLVED: Coolant Leak from the Heater Core, Replaced Under Warranty - @uthunter 1/26/2019
- SOLVED: Auto Start Stop On - Vehicle Charging - @t4thfavor 2/7/2019
- SOLVED: Ranger Went Into Limp Mode, Engine is Only Running on 3 Cylinders - @kep 2/16/2019
- SOLVED: Twin-Scroll Turbo Missing O-Ring from Factory, Replaced Under Warranty - @Lloyd C 3/13/2019
- SOLVED: Steering Wheel Not Straight, Needed Alignment - @Krzydmnd 2/25/2019
- SOLVED: Driver Side Frame 1/2 Lower, Shim Added to Rear Leaf Spring - @Gavin stevens 4/9/2019
- Truck doing some wacky things... - @Stic-o 4/25/2019
- SOLVED: Rear Console USB Ports Not Working - @toddiscdn 1/15/2019
- SOLVED: Android Auto Disconnects Multiple Times During Drive - @rangerdrive 1/23/2109
- SOLVED: Front Far Left Parking Sensor Going Off Constantly - @SlinkyFriend 1/29/2019
- Blown Passenger Speaker - @HoosierT 2/1/2019
- Productivity Screen Froze - @DaPyrate 3/7/2019
- CarPlay microphone volume level - 3/22/2019
- Factory Keypad Failure - @Monty 4/8/2019
- Lane keep assist not working. - @Jason Shaffer 4/23/2019
- SOLVED: FordPass will not connect or function as a remote - @DHare 04/23/3019
- SOLVED: Towed to dealer today - Battery died, Replaced Under Warranty - @UncleBob 5/21/2019
- SOLVED: Turn signal sounds like door ajar alert - @Recoil1 7/21/2019
- CONFIRMED: XL/XLT Trims Missing Plastic Cover for Ignition Cluster - @rangerdanger 2/1/2019
- SOLVED: Excessive Wind Noise Above 50 MPH, Window Gasket Replaced - @C.moore01 2/13/2019
- SOLVED: Seat Belt Receiver Won't Buckle, Seat Belt Buckle Replaced - @WxNerd2015 3/22/2019
- SOLVED: SuperCab Rear Seat Broken Floor Latch, Replaced Under Warranty - @MagneticRanger 6/16/2019
- Water Leaks into Door Which Causes Ice to Form on Internal Plastic Door Rod - @t4thfavor 2/10/2019
- Windshield wipers not always working - @ewaltrob 2/18/2019
- Front door locks not working on 2019 Ranger - @Tarawadet 3/17/2019
- Water in Lariat mirror turn signal - @RedlandRanger 6/29/2019
- Tail Lights not working - @ISUACE 7/4/2019
- Windshield defect-Streak in glass - @Tommy Oberon 7/15/2019
- SOLVED: Shimmer / slight lugging in rear when accelerating at low speed? - @JDCinVA 1/24/2019
- Hissing noise: any idea what is wrong? - @jjmanzano 5/14/2019
- Wheel Scratching Noise In Motion - @MagneticRanger 6/28/2019
- Smooth Braking/Brake modulation - @mike 7/10/2019
- What the #$%^ is wrong with my Ranger? - @Cerwin D. Vega 7/10/2019
- Concern Regarding Front Bumper Alignment - @SRAces 11/26/2018
- SOLVED: Can't get the back of the rear seat to lock upright - @JDCinVA 1/26/2019
- SOLVED: Missing Transfer Case Skid Plate from the Factory - @Daedalus9042 1/28/2019
- Rear Driver's Side Door Doesn't Close Flush - @PatrickM 1/28/2019
- Bed Alignment Issues from Factory - @joshua lawson 1/29/2019
- Rear Seat Bottom Doesn't Latch Securely, Rubber Feet Missing - @LewisLegacy 2/6/2019
- Sun visor loose? - @Stic-o 2/7/2019
- Discolored Driver Door Interior - @j0shm1lls 3/14/2019
- Rust in door jamb - @Roofhopper 3/15/2019
- Contaminated Paint Job! & Stick On Surface Between Windows? - @Robert Jay 3/16/2019
- Fuel Door Misaligned - @WxNerd2015 3/22/2019
- Door panel noise - @RangerKody 4/11/2019
- Driver and passenger mirrors have gap - @MHRanger 5/1/2019
- Loose Headrest - @dmeyer302 5/25/2019
- Creaking noise between bed & cab - @tivct 5/28/2019
- Hood alignment - @Craig 6/27/2019
