SOLVED: Coolant Leak from the Heater Core, Replaced Under Warranty
Discussion in 'Issues, Repairs, Warranty, TSB, Recalls' started by uthunter, Jan 26, 2019.
  1. uthunter
    uthunter Well-Known Member
    First Name:
    Greg
    Vehicle(s):
    2017 F-350 CC & 2019 Ranger Lariat Sport & 2005 Ford Explorer Sport Trac - SuperCharged
    Oct 18, 2018
    UT
    177
    187
    WXman likes this.
  2. Pinecrestjim
    Pinecrestjim Well-Known Member
    First Name:
    Vehicle(s):
    2000 Miata SE, 2004 Deville
    Oct 23, 2018
    Pinecrest, FL
    266
    115
    Oh, Nooooooooo! I think you may have won that award. And supposedly there is no dipstick to check the fluid level on these trannys.
    ETA: Can you determine where the leak is coming from?
  3. Floyd
    Floyd Well-Known Member
    Vehicle(s):
    1980 pinto V8, 1995 Mustang GT conv, 2019 SuperCab 2WD Ranger, 2016 Transit Connect
    Jan 6, 2019
    illinois
    980
    772
    ARRRRGGHH!!! :facepalm:So Sorry that happened. :fingerscrossed:I hope they just have to snug up the pan.
    But at any rate I hope they will take it right in and get you back on the road ASAP.
    Maybe they'll give you extra time on Sirius Radio (if equipped) or a free oil change...
    Like the Ice cream coupon from the dentist!:giggle:
    Tra1969 likes this.
  4. MT19RANGER
    MT19RANGER Well-Known Member
    First Name:
    JERRY
    Vehicle(s):
    Nov 10, 2018
    SIDNEY, MT
    707
    403
    Occupation:
    Garage Profiles:
    Oh, no....
  5. OP
    uthunter
    First Name:
    Greg
    Vehicle(s):
    Oct 18, 2018
    UT
    177
    187
    There's a small machined hole (I can feel it with my finger) on the aluminum part of the transmission flange right next to the bolt you can see with the drip coming off of it. This is towards the rear of the pan next to the transfer case. (The drive shaft you can see in the pic is the front drive shaft coming off the transfer case.)
    It's coming out of that hole next to the transmission pan bolt. After cleaning it up, it looks and smells more like coolant... but that's a long way from any coolant lines. I don't know what to think.
    My great grandpa started the dealership and I grew up detailing cars when I was younger so I've known some of the people there most of my life. They'll take great care of me. Just bad luck.
    Tra1969 likes this.
  6. Rinn69
    Rinn69 Well-Known Member
    First Name:
    Vehicle(s):
    Nov 25, 2018
    N. Central Iowa
    489
    373
    Occupation:
    Retired USAF MSgt
    Garage Profiles:
    Well, that just sucks !! Hope it is a good quick and permanent fix. Keep us updated :thumbsup:
  7. OP
    uthunter
    First Name:
    Greg
    Vehicle(s):
    Oct 18, 2018
    UT
    177
    187
    ^^^ It's coming out of an upward facing hole (unseen from below) immediately forward of this bolt; the one holding the rear of the transmission pan to the transmission.
    If you feel under the truck just next to topside of this bolt, you'll feel the machined hole.
    JoshE likes this.
  8. OP
    uthunter
    First Name:
    Greg
    Vehicle(s):
    Oct 18, 2018
    UT
    177
    187
    Monty and j0shm1lls like this.
  9. j0shm1lls
    j0shm1lls Well-Known Member
    First Name:
    Josh
    Vehicle(s):
    Oct 30, 2018
    SoCal, USA
    831
    824
    Garage Profiles:
    @uthunter judging by this video, it appears the gasket just isn't seated properly. They probably will just replace the gasket and fill her back up with fluids.
    Timecoded at 1:15, you can see the gasket and the hole after he pulls it off.
    uthunter likes this.
  10. OP
    uthunter
    First Name:
    Greg
    Vehicle(s):
    Oct 18, 2018
    UT
    177
    187
    @j0shm1lls
    That is the right spot. As long as its ATF, and not coolant, it should be an easy fix. My biggest concern is the viscosity and the color looked more like coolant than ATF.
    I just hope coolant isn't somehow working its way into the transmission or tracing its away along the gasket and out that hole.
    j0shm1lls likes this.
  11. rangerdanger
    Vehicle(s):
    Oct 9, 2018
    SF Bay Area
    3,378
    2,174
    Garage Profiles:
    Are you going to risk further damage by driving it in or have them pick it up with a flatbed truck?
  12. Toytec
    Toytec Well-Known Member
    First Name:
    Vehicle(s):
    Dec 16, 2018
    Durham, NC
    159
    117
    Appears to be coolant as ATF would puddle and coolant would just drip and run with the slant of the floor which this did. With the production of plastic parts and the use of sealant rather than rubber gaskets in modern cooling systems is just plain cheap if you ask me but that's their way of cheaper and faster production these days.
    Being this truck is so new, the technician will most likely be taking pictures after figuring it out, and sending that to Ford engineers to forward that onto production. My opinion this is a minor inconvenience.
  13. Floyd
    Vehicle(s):
    Jan 6, 2019
    illinois
    980
    772
    #13 Jan 27, 2019
    Are you sure its antifreeze? Touch the fluid, then touch your tongue, you will know for sure.
    I don't see how COOLANT could drip out of the Transmission??? Unless the transcooler inside the radiator is leaking into the fluid lines to the tranny. That could be VERY serious.
    Check the radiator for oil while you are at it!
    Hopefully... and probably...
    Check for coolant coming from the engine then running over the outside of trans case... Maybe just a loose hose clamp on a heater hose or something! check your carpet for antifreeze leaking inside the cab then finding its way through the floor then subsequently dripping on your transmission. Look at the cab floor from underneath above the transmission.
    Don't drive it until you KNOW FOR SURE.
  14. OP
    uthunter
    First Name:
    Greg
    Vehicle(s):
    Oct 18, 2018
    UT
    177
    187
    I texted pics to the dealer last night. He offered to meet me at the dealership today but I told him I want a flatbed on Monday so I don't have to drive it.
  15. rangerdanger
    Vehicle(s):
    Oct 9, 2018
    SF Bay Area
    3,378
    2,174
    Garage Profiles:
    The Ranger comes with free roadside assistance so either way you won’t have to pay anything. You should be able to organize a tow in the Ford Pass app.
    Marcbar82 likes this.
Share This Page
