Known Issues and Their Solutions for the 2019+ Ford Ranger
Discussion in 'Issues, Repairs, Warranty, TSB, Recalls' started by rangerdanger, Jan 29, 2019.
Thread Status:
The first post in this thread is a WikiPost, and can be edited by anyone with the appropriate permissions.
  1. rangerdanger
    Vehicle(s):
    Oct 9, 2018
    SF Bay Area
    3,464
    2,287
    Garage Profiles:
    #1 Jan 29, 2019
    Since the 2019 Ford Ranger is in the first model year of production, it was bound to have growing pains. To help new and prospective owners, lets assemble a list of problems and whether a solution currently exists.
    This is a wiki-post that can be edited by any member.
    Transmission Issues:
    1. SOLVED: Dead Transmission, Fixed Under Warranty - @khyros 7/23/2019
    Engine Issues:
    1. SOLVED: Coolant Leak from the Heater Core, Replaced Under Warranty - @uthunter 1/26/2019
    2. SOLVED: Auto Start Stop On - Vehicle Charging - @t4thfavor 2/7/2019
    3. SOLVED: Ranger Went Into Limp Mode, Engine is Only Running on 3 Cylinders - @kep 2/16/2019
    4. SOLVED: Twin-Scroll Turbo Missing O-Ring from Factory, Replaced Under Warranty - @Lloyd C 3/13/2019
    Suspension Issues:
    1. SOLVED: Steering Wheel Not Straight, Needed Alignment - @Krzydmnd 2/25/2019
    2. SOLVED: Driver Side Frame 1/2 Lower, Shim Added to Rear Leaf Spring - @Gavin stevens 4/9/2019
    3. Truck doing some wacky things... - @Stic-o 4/25/2019
    Electronic Issues:
    1. SOLVED: Rear Console USB Ports Not Working - @toddiscdn 1/15/2019
    2. SOLVED: Android Auto Disconnects Multiple Times During Drive - @rangerdrive 1/23/2109
    3. SOLVED: Front Far Left Parking Sensor Going Off Constantly - @SlinkyFriend 1/29/2019
    4. Blown Passenger Speaker - @HoosierT 2/1/2019
    5. Productivity Screen Froze - @DaPyrate 3/7/2019
    6. CarPlay microphone volume level - 3/22/2019
    7. Factory Keypad Failure - @Monty 4/8/2019
    8. Lane keep assist not working. - @Jason Shaffer 4/23/2019
    9. SOLVED: FordPass will not connect or function as a remote - @DHare 04/23/3019
    10. SOLVED: Towed to dealer today - Battery died, Replaced Under Warranty - @UncleBob 5/21/2019
    11. SOLVED: Turn signal sounds like door ajar alert - @Recoil1 7/21/2019
    Interior Issues:
    1. CONFIRMED: XL/XLT Trims Missing Plastic Cover for Ignition Cluster - @rangerdanger 2/1/2019
    2. SOLVED: Excessive Wind Noise Above 50 MPH, Window Gasket Replaced - @C.moore01 2/13/2019
    3. SOLVED: Seat Belt Receiver Won't Buckle, Seat Belt Buckle Replaced - @WxNerd2015 3/22/2019
    4. SOLVED: SuperCab Rear Seat Broken Floor Latch, Replaced Under Warranty - @MagneticRanger 6/16/2019
    Exterior Body Issues:
    1. Water Leaks into Door Which Causes Ice to Form on Internal Plastic Door Rod - @t4thfavor 2/10/2019
    2. Windshield wipers not always working - @ewaltrob 2/18/2019
    3. Front door locks not working on 2019 Ranger - @Tarawadet 3/17/2019
    4. Water in Lariat mirror turn signal - @RedlandRanger 6/29/2019
    5. Tail Lights not working - @ISUACE 7/4/2019
    6. Windshield defect-Streak in glass - @Tommy Oberon 7/15/2019
    Wheels & Tires/Brakes:
    1. SOLVED: Shimmer / slight lugging in rear when accelerating at low speed? - @JDCinVA 1/24/2019
    2. Hissing noise: any idea what is wrong? - @jjmanzano 5/14/2019
    3. Wheel Scratching Noise In Motion - @MagneticRanger 6/28/2019
    4. Smooth Braking/Brake modulation - @mike 7/10/2019
    5. What the #$%^ is wrong with my Ranger? - @Cerwin D. Vega 7/10/2019
    Fit/Finish Issues:
    1. Concern Regarding Front Bumper Alignment - @SRAces 11/26/2018
    2. SOLVED: Can't get the back of the rear seat to lock upright - @JDCinVA 1/26/2019
    3. SOLVED: Missing Transfer Case Skid Plate from the Factory - @Daedalus9042 1/28/2019
    4. Rear Driver's Side Door Doesn't Close Flush - @PatrickM 1/28/2019
    5. Bed Alignment Issues from Factory - @joshua lawson 1/29/2019
    6. Rear Seat Bottom Doesn't Latch Securely, Rubber Feet Missing - @LewisLegacy 2/6/2019
    7. Sun visor loose? - @Stic-o 2/7/2019
    8. Discolored Driver Door Interior - @j0shm1lls 3/14/2019
    9. Rust in door jamb - @Roofhopper 3/15/2019
    10. Contaminated Paint Job! & Stick On Surface Between Windows? - @Robert Jay 3/16/2019
    11. Fuel Door Misaligned - @WxNerd2015 3/22/2019
    12. Door panel noise - @RangerKody 4/11/2019
    13. Driver and passenger mirrors have gap - @MHRanger 5/1/2019
    14. Loose Headrest - @dmeyer302 5/25/2019
    15. Creaking noise between bed & cab - @tivct 5/28/2019
    16. Hood alignment - @Craig 6/27/2019
    kieefer, Shaggy1911, Pflip and 2 others like this.
  2. FX4Offroad
    FX4Offroad Well-Known Member
    First Name:
    J
    Vehicle(s):
    2014 F150 FX4
    Jan 21, 2019
    South Florida
    401
    431
    I've also heard about a rear door not flush when closed.
  3. OP
    rangerdanger
    Vehicle(s):
    Oct 9, 2018
    SF Bay Area
    3,464
    2,287
    Garage Profiles:
    Where is the post?
  4. Lloyd C
    Lloyd C Well-Known Member
    First Name:
    Lloyd
    Vehicle(s):
    2016 Lexus RX350
    Jan 13, 2019
    Fort Collins, Colorado
    89
    No break controller for towing and no apparent pre wire for after market add.
  5. OP
    rangerdanger
    Vehicle(s):
    Oct 9, 2018
    SF Bay Area
    3,464
    2,287
    Garage Profiles:
    No brake controller is not a factory defect, but pre-wire might be
  6. MT19RANGER
    MT19RANGER Well-Known Member
    First Name:
    JERRY
    Vehicle(s):
    Nov 10, 2018
    SIDNEY, MT
    778
    471
    Occupation:
    Garage Profiles:
    I also read that issue, but can't find it on the forum w/ the search. maybe it was in blue oval that I read it...
  7. OP
    rangerdanger
    Vehicle(s):
    Oct 9, 2018
    SF Bay Area
    3,464
    2,287
    Garage Profiles:
    Found it, check the original post.
    MT19RANGER likes this.
  8. Stevie Gee
    Stevie Gee Well-Known Member
    First Name:
    Vehicle(s):
    Nov 5, 2018
    Orange County/Rancho Santa Margarita, CA
    260
    444
    Occupation:
    Retired Fed
    Garage Profiles:
    Let’s hope the increased production and “massive overtime” with 3 shifts building them do not add to the problems.
  9. Fordmam@1208
    [email protected] Active Member
    First Name:
    Scott
    Vehicle(s):
    17 F150
    Dec 12, 2018
    Toledo
    Passenger side door speaker blown at the dealer now being replaced.
  10. OP
    rangerdanger
    Vehicle(s):
    Oct 9, 2018
    SF Bay Area
    3,464
    2,287
    Garage Profiles:
    I thought that was an issue with @HoosierT? You have it too?
  11. HoosierT
    HoosierT Well-Known Member
    First Name:
    Tyler
    Vehicle(s):
    Feb 1, 2019
    Fishers, IN
    568
    634
    You bet, still waiting for the speaker to come in.
  12. OP
    rangerdanger
    Vehicle(s):
    Oct 9, 2018
    SF Bay Area
    3,464
    2,287
    Garage Profiles:
  13. OP
    rangerdanger
    Vehicle(s):
    Oct 9, 2018
    SF Bay Area
    3,464
    2,287
    Garage Profiles:
  14. t4thfavor
    t4thfavor Well-Known Member
    First Name:
    Chance
    Vehicle(s):
    2019 Ranger XLT, 2011 Ford Edge Sport
    Feb 5, 2019
    1,556
    787
    I believe this is normal operation, it's been crappy here, and the defroster has been on auto, so I think that is the culprit.
  15. OP
    rangerdanger
    Vehicle(s):
    Oct 9, 2018
    SF Bay Area
    3,464
    2,287
    Garage Profiles:
    Let's take a few days to see if it reoccurs. If not I'll mark it solved.
    t4thfavor likes this.
Thread Status:
Share This Page
