Not satisfied with fox 2.0 lift - options after install
jspetree
Jonathan
Fort Worth
2020 Ranger XLT
Attorney
I purchased and installed the fox 2.0 coilovers on my '20 Ranger xlt. I love the improvement in ride quality, but there is still a noticeable rake and it isn't quite as lifted as I would like.
Would it be possible to keep the fox 2.0 setup while adding something like Ford Ranger Lift's 3" lift (https://fordrangerlifts.com/shop/ols/products/2019-ford-ranger-lifts-3-level-lift-201-frd-rng-lft) to get where I want? Or should I replace the fox 2.0 with something like ICON's 3" lift? The latter option seems cost prohibitive.
One more consideration: if I am able to stack a 3" lift kit on top of the fox 2.0's, will I need to get upper control arms?
Thanks for any help!
jspetree
Jonathan
Fort Worth
2020 Ranger XLT
Attorney
Pic to see post-installation stance. It is definitely improved over stock, but I would like a full level and a slightly higher lift.
rang19ca
Chuck
Carpinteria Ca
Retired Diesel Mechanic
I beleive that you can go up to 2 1/2 inches.
Something to keep in mind while you’re reaching for the stars! 2 1/2 is about the norm to level out the truck from the front. At some point not far past that is when major mods have to be done so everything continues to play nice. To get to 3” you would have to replace the UCA’s, and lower your front differential so your CV’s don’t bind.
How long before you want bigger tires?
See, it doesn’t stop.
Where you are now you could push front a little higher with shock adjustment but I would be cautious doing so.
jmurph
jake
Alaska
2021 XLT Ranger
Gov
bigger tires would make the gaps less noticeable to the eye id think. but depends if you actually want the bigger tires.
Tom_C
Virginia, USA
System Admin, Retired
I think your truck looks fine. I've gone back and forth thinking about upgrades. For me, after some soul searching, I'm going to stay with stock tire size. I didn't want to have to change the spare. I replaced the rear shocks, but not the front. I like the change in the ride, and I can tell the front are sort of soft, but I'm going to live with it. I have the rake, but I'll live with it.
But, hey, you do you.
Well to start you did not lift the truck..... You leveled it....... By 2 inches at best because I have a feeling you did bot make adjustments to the front struts before install.....
If you really want to lift the truck then you go with a lift kit. Now mind you sonce you do have the Fox kit the rear shocks can handle a fair amount of lift so you could just swap out leaf springs.
Now if you actually want to level the truck then just simply have the front struts adjusted, add some upper control arms and get an alignment again....... Just do yourself a favor and dont use your truck as a truck if you go this route......
Bob902
St. Louis
RETIRED!!!!
I did the same to my truck for the exact reasons you listed. Very happy with the tears only and the much improved ride.
Stangman570
Florida Panhandle
2019 Ford Ranger 4x4 XLT Sport
Not exactly... I've been running a 3 in level since 2019 with no binding of the cv's nor the UCA's. 3.5in is the sweet spot where you run into these issues.
azdriver
Arizona
2021 Ford Ranger Lariat FX4
System Administrator I
This is the difference that putting bigger tires on makes on the look of the truck
This is stock tires
This is with Falken WildPeaks A/T3w 265/70R18
azdriver
Arizona
That's with the stock suspension. I'm having the FP Fox 2.0 kit installed tomorrow morning.
Pinepig
Charlie
Sacramento
Last count was 12
lol
It'll end up looking somewhat like this, ignore my glider.
For the OP I'm led to believe your front coilovers were not adjusted properly for the full level/lift when they were installed. Mine has the Ford performance version of the Fox 2.0 that are adjusted correctly when you receive them.
