The Dreaded Water in Spark Plugs (TSB 21-2147)
puckdodger
Oshawa
Absolute BS from Ford regarding an obvious manufacturing defect. Ford is really pissing me off with these reactions to their poor engineering problems. I hope you can work some kind of satisfaction from these ? ?s…
username checks out.
I am with the gang on this one, Ford should be on the hook here. Be polite, be persistent, and everything will all work out fine. I mean, what could possibly go wrong when you're dealing with the stealership.
Gizmokid2005
Gizmokid2005
GA
gizmokid2005.com
SQL Developer
Yeah, I'm always polite and understanding, and can be very persistent.
Per the Ford rep, it was never even submitted to Ford because the tech told the SA it wasn't covered under warranty. He's going to follow back up and see what's going on. If I have to go drive out there today and have some face to face words, it's on the calendar. Shouldn't have to fight like this for something this stupid, it's not like they're going to get screwed on the warranty hours for this repair, it's not even 10 minutes of work to replace the boots, plugs, and install the cover, and the cover alone pays 0.3 per the TSB.
Jason B
Louisiana
2021 XL STX SE 4x2
machinist
That's some crappy going on there. Why is the Tech deciding what's covered or not?
That SA new at his job or something?
Gizmokid2005
Gizmokid2005
GA
gizmokid2005.com
SQL Developer
No idea, honestly. I know he's a new SA - but he's been miles ahead of any other SA I've dealt with out here still. All this plus $205/hr shop rate for labor at this stealership too.
NotBudule
XLT
deleriumtremor
Bill
Boise ID
2022 Ford Ranger XLT FX4
If you have to , just refer them to the forum here and the hell and damnation it can bring to them ... they tried this with another guy on here a while back and his plugs WOULD NOT come out , so he needed a head also , they eventually caved and covered it...
Engine Cover TSB 21-2147 Warranty Voided | 2019+ Ford Ranger and Raptor Forum (5th Generation) - Ranger5G.com
I remember that one. The dealer (a big one in a prosperous area) really tried to screw this guy over, claiming because he didn't perform the TSB, he was on the hook for the corrosion. Like a customer knows about TSB's.
I am still trying to understand how someone gets repeated water pooling in number 1, cover or not.
I have the cover and when I went through the car wash I always had a big puddle of water on the number 4 coil pack. The cover and the other three coil packs were always dry. I made a dam of black high temp RTV to keep the water from pooling and running off that center clip, everything is dry now after a car wash or heavy rain.
Dieseldean1
Reno
2020 Ranger
So, it got me finally after 60k, last week I was pulling out of a restaurant and started to feel some hesitation, then a misfire, then the CEL and blinking CEL. Limped home and popped the hood, plug 1 was full of water...
I didn't even pull the others, I knew it was bad enough from this, and knew that TSB 21-2147 existed and despite being just over 60k, I have a top-tier ESP from Ford as well. Had it towed to the dealership on Thursday and he got back to me today, Ford won't cover it under factory warranty, ESP won't cover it, the TSB isn't active anymore - it's apparently been superseded by a new TSB with the exact same language in it.
Total damage?
He's willing to knock off the $205 in labor (which is 1 hour at this place, for the diag), but that still leaves ~$740 for the replacement work (including $250 for the cover itself....)
I'm not sure if furious is angry enough right now.
Ask the dealership for the phone number for the Ford Appeals board.
then, give them a call.
make sure you get the number from the place sound the “work”.
JustSteve
2019 Ranger XLT
Oil is fine, the fuel in oil stuff in here is basically conspiracy level at this point, I've followed the thread since its inception.
Since the water in the spark plugs hasn't happened to me, I think it is basically conspiracy level at this point.
Gizmokid2005
Gizmokid2005
GA
gizmokid2005.com
SQL Developer
I see what you think you're being clever about there. Where's the TSB about fuel in the oil? Most of the fuel-in-oil stuff is about people not understanding how FI-DI engines work and how the fluids change over time. I'm not at all saying there *isn't* some vehicles with problems (leaky injectors or HPFPs, etc), but it's not something that Ford has even acknowledged in a TSB to address.
Gizmokid2005
Gizmokid2005
GA
gizmokid2005.com
SQL Developer
Ford checked it and said it was all good !
I mean, while, especially with this current debacle - which is apparently ENTIRELY tech caused, saying it's not covered for...reasons? - Ford isn't great at agreeing to things, if the spark plug issue got a TSB, I'd expect that a fuel leak/oil issue would get some kind of bulletin if it was a widespread issue. ?‍♂ Off-topic regardless.
NotBudule
XLT
I think the issue is that , even if , it has yet to cause a problem , other than worry ...
dtech
colorado
Look on the bright side, IIRC the gargantuan bill GTGallop received prompted him to dump his ranger, but he did get a new ignition coil, albeit at an outsized dealer markup.
Curious if you authorized the repair before knowing whether it would be covered by your ESP. Some states (CO) have to have customer authorize the cost before repair can proceed, your issue somewhat reminds me of medical stuff and dealing with insurance, I always contact the insurance and have them put in writing what will be covered and how much I'm responsible for so the hospital or MD office don't try to jerk me around - and believe me some try to do their best.
What is the value of high level ESP coverage if they don't cover stuff like your repair.
Gizmokid2005
Gizmokid2005
GA
gizmokid2005.com
SQL Developer
Luckily getting this quote was them trying to get authorization. I don't know why it took days for the tech to get it figured out and for him to say that they wouldn't warranty it and workup this quote. I went and talked to them this afternoon, with the updated TSB (thanks @alcohenusa !), and told them it explicitly says the ESP should cover this. Apparently he knocked some sense into the tech and is working on figuring it out with his manager, I'm supposed to hear back this evening or in the morning with final confirmation.
(I'm also in the middle of a bunch of medical stuff, so that hits real close to home too, and I absolutely understand the sentiments there...)
That's also my point, if I paid almost $1900 for the highest coverage I can get (with a $50 deductible) and this kind of crap still isn't covered, what even would be?
