Jeff in Ohio
- Thread starter
- #1
So, with all this hub-bub about engine covers I decided to take a look. This is a 2020 with 13,000 miles that sits outside in Ohio all the time facing downhill. . Spark plugs 2-4 were pristine. Number 1….not so much…. I’m calling #1 at the front of the motor. So, I used dielectric grease on the top of the coils seal and then a bead around the ridge on the valve cover where the coil pushes down as step one going forward. The leak point is where Ford split the cowl cover where a push fastener is. . I put a pan on top of the motor and it has been a light steady rain for around 5-6 hours. Look at all that water it collected. Next step will be to seal the cowl cover to the cowl and eliminate the leak point.
