rangerdanger
- Joined
- Oct 9, 2018
- Threads
- 194
- Messages
- 3,489
- Reaction score
- 2,635
- Location
- SF Bay Area
- Vehicle(s)
- 2019 Ford Ranger SuperCrew XLT FX4
- Vehicle Showcase
- 1
- Thread starter
- #1
Let’s post here useful FORScan modifications for the 2019+ Ranger
In case you forget what the original setting was... Lookup Module Build Data (As-built) by VIN: https://www.motorcraftservice.com/AsBuilt
As of 5/11/2019 Much of this (not all) is built into FORScan as "Service Procedures". You should no longer have to manually edit the as-built data as there should be easy to use menu options available.
OBDII ADAPTER:
This is recommended as it was developed with the team at FORScan. https://www.amazon.com/gp/product/B081VQVD3F/ -- (RCMUSTANG)
https://smile.amazon.com/gp/product/B083FML519/ -- (Gizmokid2005)
Note that in the table below, the "Setting" is the name of the GUI option in FORScan in the appropriate module location. You do not need to use the AS-BUILT data (nor modify it) if you use the GUI settings instead. They all exist unless otherwise noted.
Andy & WLFPIR8 (For the write up)
Enable Speed Limit Sign Display (Read by camera) in Lariat.
https://www.ranger5g.com/forum/threads/forscan-modifications.1844/post-143642
This is a link to the F150 Excel spreadsheet with all of their mods, its very thorough and technical, I have tried some not all obviously. Proceed with caution if venturing into the unknown. -- (John Galt)
NOTE: FOR INTERNATIONAL RANGER OWNERS. There are many differences with those models and what works with the North American version. This website can answer or has done many of the requests I've seen asked here. They are based on international Rangers. https://www.saeb.net/index.php
OBDII ADAPTER:
Setting | Description | Module | AS-BUILT Code | Credit |
AM FM Menu | Diables AM/FM Menu in Entertainment Screen (Lariat Only) | IPC | RCMUSTANG | |
Auto Relock Time Duration | Enables 30 or 45 second auto relock if doors unlocked with keyfob but are not opened. Works with double-honk disabled | BdyCM (BCM) | Porpoise Hork (Upd: Gizmokid2005) | |
Average Speed Display | Display average speed | IPC | RCMUSTANG | |
Average Speed RPM | Display average RPM | IPC | RCMUSTANG | |
BMS / Auto Stop Start System | Disables the Auto- Start/Stop system NOTE: The button and dash indicators still function but do not do anything. | BdyCM (BCM) | 726-48-02 (x#xx xxxx xxxx) 0 - Off (Permanently) 1 - On (Default) | Gizmokid2005 / Akshon (AS-BUILT) |
Chimes - [Driver/Passenger] Belt Minder | Disables seat belt reminder charms (Two settings in non-AS-BUILT) | IPC | 720-01-01 (xxxx xx#x xxxx) 0 - Both 2 - Driver 4 - Passenger | |
Chimes - Vehicle Running Door Open | Disables chime when door opens with engine running | IPC | RCMUSTANG | |
Chimes - Primary Source | Selects the primary source for chimes. Defaults to speakers. | IPC | 720-01-01 (xxxx xxx# xxxx) 0 - Internal Speaker Only 2 - Forwarded to ACM/Vehicle Speakers (Default) NOTE: IPC Only will NOT have automatic audio mute feature for chimes/warnings (Depending on firmware version) | RCMUSTANG (Upd: Gizmokid2005) |
Climate Menu | Climate View on Lariat right side instrument screen (Cannot change climate, only for view.) | IPC | 720-05-01 (D8B8 xxxx xxxx) | John Galt |
Corner Light Mode for Fog Lights | Triggers fog light based on steering input (left vs right illuminated) | BdyCM (BCM) | Gfitzge2 | |
Dark Car | Police option (Enable in conjunction with Silent Mode Control Menu) | BdyCM (BCM) | 726-32-01 (xxxx x#xx xxxx) 0 - Disabled (default) 1 - Enabled NOTE: IPC: 720-04-01 (xxx# xxxx xxxx) 0/1 - add 4 to the value as shown below: 4 - Disabled (default) 5 - Enabled | RCMUSTANG |
Daytime Running Lights Includes Parklamps | Enables parking lights when DRLs are on (useful for raptor style lights in grille) | BdyCM (BCM) | Gfitzge2 | |
Disable Front Turn Signal Hyperblink (No GUI setting as of 2.3.37) - update: now can be disabled under BdyCM "Front Bulb Turn Outage" setting | Disables the hyperblink indicator when a bulb is out or LEDs (without resistors) are used in front turn signals | BdyCM (BCM) | 726-27-01 (x0xx xxxx xxxx) | j0shm1lls |
Disable Rear Turn Signal Hyberblink (XL Trim) (No GUI setting as of 2.3.37) | Disables the hyperblink indicator when a bulb is out or LEDs (without resistors) are used in rear turn signals on XL models only | BdyCM (BCM) | 726-28-01 (x0xx xxxx xxxx) | j0shm1lls (unverified) |
Disable Startup Chimes (3x doo-doo-doo) | IPC | 720-01-02 (xxxx x2xx) | RCMUSTANG | |
Double Honk on Leaving Cabine | Disables the double-honk when closing door with key in. | BdyCM (BCM) | 726-41-02 (xxx0 xxxx xxxx) | Gizmokid2005 / j0shm1lls (AS-BUILT) |
DTE Calculation option in Productivity Screen | IPC | Arron | ||
Fog lights if High Beam is on (AKA - Bambi Mode) | Allows the fog lamps to stay on when the high-beams are used. | BdyCM (BCM) | 726-27-01 (xxxx xxx0 xxxx) | Gizmokid2005 / RCMUSTANG (AS-BUILT) |
Front Bulb Turn Outage | Can be used to disable instrument cluster hyperblink if switching to LED bulbs | BdyCM (BCM) | RCMUSTANG / SVTPaul | |
Frost Telltale (Below 5°C) | IPC | Arron | ||
Fuel Consumed Per Hour Display | Show fuel consumed per hour instead of instant MPG | IPC | RCMUSTANG (Upd: Gizmokid2005) | |
Instant Fuel Economy Display | Changes instant MPG display between bar and numeric display | IPC | Arron | |
Intelligent 4WD Gauge | (Partially works (shows trail mode option selected) but does not show individual wheel response) (enable in conjunction with Intelligent 4WD Gauge Mode Feature) | IPC | Arron | |
Intelligent 4WD Gauge Mode Feature | (Partially works (shows trail mode option selected) but does not show individual wheel response) (enable in conjunction with Intelligen 4WD Gauge) | IPC | Arron | |
Low Beam Outage | BdyCM (BCM) | RCMUSTANG | ||
Navigation in Motion | Speed limit signs will look European and FM radio stations will be 2 decimals (101.70 vs 101.7). 911 Assist will be disabled | APIM | 7D0-02-01 (5753 xxxx xxxx) | John Galt |
Off Road Gauge | Enables Off-road gauges (enable in conjunction with Off-road Screen) | IPC | Gizmokid2005 | |
Off-road Screen | Enables off-road gauges (enable in conjunction with Off Road Gauge) | IPC | 720-07-02 (x3xx xxxx xxxx) | Gizmokid2005 / WhiteLightning19 (AS-BUILT) |
Panic Activate | Changes behavior of Panic Button behavior on KeyFOB | BdyCM (BCM) | 726-37-01 (xxxx xxx# xxxx) 0 - Panic on FOB Disabled 1 - Panic on FOB requires 2 presses 2 - Panic on FOB Enabled (Default) | Gizmokid2005 / AS-BUILT info uncredited |
Park Aid Control Front | IPC | RCMUSTANG (Upd: Gizmokid2005) | ||
Park Aid Control Rear | IPC | RCMUSTANG (Upd: Gizmokid2005) | ||
Power Point Timeout, s | The timeout period for the power point in seconds | BdyCM (BCM) | 726-39-01 (0001 0101 006A) - For 1 second timeout | RCMUSTANG / John Galt (AS-BUILT) |
Radio Without Ignition Switch | Allows radio use without the ignition (Enabled by default) | APIM | RCMUSTANG (Upd: Gizmokid2005) | |
Radio Without Ignition Switch play time | Time (in minutes) to allow the radio to run without shutting down or ignition on. (20, 30, 40, and 60 minute options) | APIM | RCMUSTANG (Upd: Gizmokid2005) | |
Rear Bulb/LED Turn Outage | (Bulb or LED option depending on model) | BdyCM (BCM) | RCMUSTANG (Upd: Gizmokid2005) | |
Secure Idle | To idle the car with the key not in vehicle, cannot shift from park) | BdyCM (BCM) | 726-42-01 (x1xx xxxx xxxx) | John Galt |
Selectable Drive Mode | Enables the Terrain Management selectable drive modes (requires TM enabled 4x4 control knob) | IPC | Gizmokid2005 | |
Silent Mode Control Menu | IPC | Arron | ||
Software Engine Sound Enhancement | Disables the "piped in" sound through the speakers | ACM | Gizmokid2005 | |
Splash Screen | Sync 3 Boot/splash screen | APIM | 7D0-02-01 (xxxx x#xx xxxx) 3 - Lincoln Black Label 5 - Raptor 6 - Mustang 9 - GT350 B - ST M C - RS M D - GT Car M NOTE: There are others in the spreadsheet linked but I did not try them. | John Galt |
Steering Wheel Switch Packs | SCCM | Left Switch: 724-02-01 xx#x.xxxx.xxxx 1 - Standard Cruise 2 - ACC Right Switch: 724-02-01 xxx#.xxx.xxxx 0 - Lariat Media 1 - Standard Audio | SOHK_Alumni | |
TPMS Placard Pressure Display | Displays the factory placard tire pressure in the Tire pressure display. | IPC | 720-04-01 (xx#x xxxx xxxx) 0 - Disabled (default) 8 - Enabled (show placard value) | Gizmokid2005 / Akshon (AS-BUILT) |
Trailer Tow LIghts Outage | BdyCM (BCM) | RCMUSTANG | ||
Variable Line Level Audio | Enables variable line level audio output on the non-B&) radio | ACM | 727-01-01 (xx50 xxxx xxxx) | Ed Venture |
Vehicle Cluster Images | Changes vehicle image between Truck and SUV (Utility / SUV) | IPC | RCMUSTANG (Upd: Gizmokid2005) | |
Welcome Goodbye Backlighting | No Blue Sky Background on IPC when getting into vehicle | IPC | 726-03-02 (xxx4 xxxx) | RCMUSTANG |
