- Joined
- Aug 24, 2022
- Threads
- 28
- Messages
- 4,449
- Reaction score
- 8,507
- Location
- Midwest - KS
- Vehicle(s)
- 2022 Ranger Lariat-Super Crew, Cactus Gray
- Occupation
- Aircraft Tech
The Ranger charging system is different than an old school charging system, for the sake of fuel economy at factory settings it maintains the battery voltage at a 70 to 75 percent State Of Charge (SOC).I'm confused, why would the system voltage go up under coast down or braking? I have a 2022 Lariat, it's not a hybrid and I ordered it with start/stop deleted (I ordered it in California if that matters). The Ford performance handheld was also ordered and the dealer installed the tune prior to delivery. Am I missing something?
It incorporates Regenerative Charging - by using a OAD (Alternator) (Overdrive Coupling)
When in the right driving setting (daytime) no lighting loads the charging output from the alternator can be as low as 12.2 volts, with the help of FREE energy from the engine Touque when coasting to a stop, the charging system will jump up to as much as 15.1 Volts
I took a deep dive into how this system works, and TJC and others have devised a way to overcome the way the system operates to provide a more traditional way to charge the battery.
You will get many different opinions here on what to do.
For me upping the SOC to 90% - Works for me, I monitor it with every drive and have noted I never see any charging voltage below 13.7 now.
I suggest you read these threads (be prepared they are very long posts) with lots of info
Charging Sys-Full Description-Trigger Voltages-Test Results | 2019+ Ford Ranger and Raptor Forum (5th Generation) - Ranger5G.com
Maximizing Battery Life | 2019+ Ford Ranger and Raptor Forum (5th Generation) - Ranger5G.com
