anyone install the Tonneau hard folding cover
RobertU
New York
2019 Ford Ranger Lariat, 2001 Ford Ranger XLT
Here is a picture from the inside and the outside with the rubber sealed held up so you can see the top of the bulkhead, rail, and weather strip. This is on the Undercover Flex. The rail mounts just like @MRAces said his Bakflip MX4 mounted. Undercover and Bakflip are both made by Truck Hero so they probably use a lot of the same parts like Chevy and GMC do on there trucks.
I appreciate the responses from all of you. It will certainly make it a lot easier for me to do the install.
those drip lines go right through one of the exposed holes on side of the bed? I'm going to do the same thing.
FX4Greg
Greg
Independence, MO
2018 Jeep Wrangler JL Unlimited Rubicon, 2019 Ford Ranger Screw cab Lariot FX4
The installation instructions dont say how to run them out of the bed. But the holes on the side near the front are the perfect size and height for the drain tubes. Just have to cut off the excess length. They were way to long.
FX4Greg
Greg
Independence, MO
Here’s a picture
In your picture it doesn't look like your rear clamp is on good. May just be the picture but it looks like the clamp is at an angle like the backside isn't up all the way.
WhiteLightning19
FX4Greg do you have a picture of where you installed the drain tubes?
Rp930
Denver
The lower of the two factory holes near the front top on each side.
That looks perfect. Waiting for truck to arrive. MX4 ordered.
srgredranger
Scott
Lawton,Oklahoma
Setup tech / Goodyear
Thanks for pointing that out, I will look at it tomorrow
PonyXpress
PonyXpress
Sacramento CA
For the new backflip Ford model part number is VKB3Z-99501A42-G
Can anyone please confirm if this is the new MX4?
VAMike
2019 Ranger Lariat SuperCab
The description says hard rolling, not hard folding. Not sure why you think they're changing the cover.
PonyXpress
PonyXpress
Sacramento CA
Oh my, you are correct and that is likely why the dealership is having a issue. I didn't read that close enough. The G is the rolling, not what I want, so thank you!
When I go to accessories.ford.com and search for the cover I ordered with my truck, hard folding for 5' bed, the part is VKB3Z-99501A42-C. However, it has been discontinued. When you click on the item, it says it's no longer available.
If you go to this link, you see this
https://accessories.ford.com/catalogsearch/result/?q=VKB3Z-99501A42-C
And then when you click on it, you get this:
So as of right now, there isn't a working link for the hard folding cover for 5' bed. I need the Ford part number for the replacement model. Maybe somebody with the 5' bed that ordered with your truck and received it in the past week or so, you likely have the new model. Please share the Ford part number if that is the case. :)
I'm also trying to call them, but they don't make it easy by hiding the customer service phone number :(
PonyXpress
PonyXpress
Sacramento CA
Or if anyone has the MX4 (for 5'bed) with a Ford part number on it - please share. I'm not getting any where with Ford customer service, geez....
FX4Greg
Greg
Independence, MO
I would just have the dealer refund what you were charged for the cover and buy an aftermarket one so you can get exactly what you want. You can probably get a better cover for a lower price.
PonyXpress
PonyXpress
Sacramento CA
The dealer agreed to refund so I'll be looking at the aftermarket options. UnderCover just released a new model, Armor Flex that looks good. Has anyone purchased that one and can offer feedback?
https://www.autoanything.com/tonneau-covers/undercover-armor-flex-tonneau-cover
This may not work for me, as I have the Ford drop in bed liner. I opened a Chat with Autoanything,and the guy said this cover will not work with a drop in bed liner, unless you cut the top of the bed liner off all the way around it. Huh?? I have the Ford drop in that I ordered with my truck so I need to confirm if the UnderCover ones will work.
More research needed before deciding which one to buy....
FX4Greg
Greg
Independence, MO
You don't have to cut it all the way around. But you do have to cut the liner at the front of the bed on each side so the rails can slide all the way forward. That's not just the Undercover but all of the covers that have the rails that clamp onto the side.
On a side note, BAK is offering a $100 mail in rebate on the BAKFLIP MX4 thru 5/13/19 https://bakindustries.com/special-offers
PonyXpress
PonyXpress
Sacramento CA
can you please confirm which bed you have? I have the short bed 5'. The reason I ask is because the instructions for the cover I'm returning to the dealer say that if you have the 6' bed, you need to cut the notches as you described. However with 5' bed, no cutting required.
I'm also taking a close look at the UnderCover Elite LX Tonneau cover. The bad news is that it cost $1500, and I haven't found any sales or deals to bring down the price. I really like the look and it has a much better seal for water protection..
https://www.autoanything.com/tonneau-covers/undercover-elite-lx-tonneau
The one question I have is, can the tailgate open and close without having to open the cover?
Here is a pic of it, but I would like to see a pic of this installed on a 2019 Ranger, and get feedback from anyone who has this cover.
