What are you guys towing?
GoldenAtlas
2015 Tundra
If it has the quick lube type with the zerk the proper way to lube them is to raise the tire/wheel off the ground so you can just rotate the tire/wheel as you pump grease into the fitting. This allows the grease to enter the bearings as you rotate. If you don't do this, and just grease while the tire/wheel is on the ground, the grease basically just fills up the outer area of the quick lube cup.
yeah we did all that. Lifted the tires and rotated the wheels. Grease came out in a uniform circle around the hose of the gun. I guess the videos I watched on how to do it the grease was much dirtier and easier to see what was new than when we did it. I also didn’t know if I was supposed to leave it in there like that since that is how it was whenI opened it or if I’m a moron and all that matters isthe unseen grease in the axle
ctechbob
Shawn
2020 Ranger XL/FX2/STX
Adult Daycare
I'd say that if it was coming out clean, that's a good thing. I know it takes a TON of grease when it is a brand new axle, unless the factory was generous enough to fill them up for you. It took me just about a complete 3oz tube per axle before I could even see anything coming out. They just grease the bearing from the factory, which isn't a bad thing, but the first time using the EZ Lube's it takes a pile to fill them up, most of that grease just sits in there and doesn't do anything though, its just in there taking up space.
Arly
Arlyn
Houghton MI
trails maintenance
Our new camper. stilling working on all its short comings. Also need to work on brake controller thingy to stay on where my BIG feet hit it getting in and out. :crazy:
Arly
Arlyn
Houghton MI
trails maintenance
Just get a bit of fresh grease in it yearly. Keeping it full helps to keep the water and dirt out. Don't over think it. We don't jack up none of ours to do it.
ProtonDecay
Derek
Bay Area, California
'21 Ford Ranger XLT
I highly recommend switching out to oil bath hubs - it is not expensive, at least for my trailer, and the piece of mind from being able to quickly check/change the oil is precious. Here's what I got: https://www.easternmarine.com/kodiak-xlprolube2440-kit and you'll probably also want to keep a bit of this around: https://www.easternmarine.com/lucas-oil-hub-oil-10088
Fordup
Ed
NY
youtube.com
Retired YouTube Creator
Just picked up the new mower, side by side, and tractor trailer. Only weights 990 lbs and you don't even know it's behind you empty. Carries 6k pounds and should polish up nice. Just need an 8 inch drop hitch to level it. The back of these Rangers is definitely too tall. Tried the golf cart first and didn't drag in the middle so everything else should be no problem. Now to start the mods.
Arly
Arlyn
Houghton MI
trails maintenance
What are the specs on that trailer?
Don't ask to much more. We've only had it out once!
UVW (Unloaded Vehicle Weight)*2,980
Dry Hitch Weight*430
Dry Axle Weight*2,550
CCC (Cargo Carrying Capacity)520
GVWR3,500
Interior Height78"
Exterior Height (without A/C) Unless Noted**112"
Exterior Width84"
Exterior Length***22'
Refrigerator (Cubic Feet)8
Water Heater Cap. (Gal. LP w/DSI)6
Fresh Water Cap. (Gal.)20
Waste Water Cap. (Gal.)26
Gray Water Cap. (Gal.)28
LP Gas Cap. (Lbs.)20
Furnace BTUs (1,000s)20
Tire Size15"
Awning12'
*This weight reflects the rolling average unit weight for each model. Your trailer weight will vary according to optional equipment.
**This exterior height is with A/C.
***Exterior length is measured from rear of bumper to leading edge of coupler.
MT2003
2021 Ford Ranger XL STX 4X4, 2008 Mercury Mariner
Manufacturing Tech
I'm curious, has anyone towed a small skid steer on a light duty equipment trailer?
I've spec'd out a combination that would be within capacity, just curious if anyone else has done so.
reidmefirst
Reid
Des Moines, Iowa
2021 Ranger
Computer stuff
I've posted pics of my boat before ( https://www.ranger5g.com/forum/threads/what-are-you-guys-towing.1768/page-91#post-544099 ), but I finally towed it some distance. I went from Des Moines, Iowa to Port Washington, Wisconsin (~400 miles) with it last week. And back, of course, though the return trip was a little different route. Towed perfectly well. I got ~10.8mpg on the outbound trip there (according to the trip computer) using 91 octane. We had a lot of headwind on the way to Lake Michigan, something like 30mph wind off the lake.
On the way home I fueled up with 93 octane for my first tank, and we had a tailwind about the same as my drive out. I was getting 15mpg, according to the onboard computer. I made it from Winthrop Harbor, IL all the way back to Iowa City on the first tank (~260 miles), then refilled with 91 octane and MPGs dropped to 13. We still had a good tailwind, so not sure if the economy decrease was due to the fuel or the increasing hills.
Anyway, the truck towed the 6000+ pounds payload with no problems. I went 68 on the highways (speed limit was 70), usually slowed down a little as semi trailers passed me to make the air shockwave a little easier to handle. Easy peasy for the truck. Trailer sway would start at about 72mph, which was exactly how the Uhaul/Silverado 1500 behaved when I towed with that. On the drive out the headwind stunk though, had to stop for fuel several times. On the way home we were ready for a pit-stop by the time the fuel was getting empty, so no real complaints there.
Fun times. Hopefully the truck lasts me a while. It is mighty handy to be able to move the sailboat without renting a truck.
Raygunn
Reagon
Texas USA
2020 Ranger FX4
Building Automation
Just back from a 500 mile round trip with the newly updated, and what I consider, the final version of, our setup. Fully loaded for 3 people and about 10-15 gallons of water in the fresh tank.
And the Blackstone Tailgator in the bed, because is is about 1" too tall to fit in the f-ing basement of the trailer without taking it apart.......damnit.
--Edit--
We highly recommend the James Island County Park campground. Super nice facility, although a little high for a county park, it is a very very nice park.
NICE RIG! What's the weight/tongue weight? I'm looking to upgrade to a Salem FSX at around 4000/450 and not sure....
