ctechbob
Just a side note. Forest River includes propane in their weight, Jayco does not. Splitting hairs I know.
Well, no not completely accurate. Part of the weight added forward of the axle will be added to the tongue weight, but not all. If you have 20 feet between hitch and front trailer axle, and you add 200 pounds 10 feet in front of the axle the weight will be split between axle and hitch.Now, add to that any weight that is placed forward of the axles,,,,food, dishes, cookware, and dozens of other items that will be stored in cabinets. All that gets added to the tongue weight.
I post in general terms when answering questions. Yes, I am aware of weight placement over the axle, in front of the axle and all the way forward toward the hitch point.Well, no not completely accurate. Part of the weight added forward of the axle will be added to the tongue weight, but not all. If you have 20 feet between hitch and front trailer axle, and you add 200 pounds 10 feet in front of the axle the weight will be split between axle and hitch.
The farther forward, the more weight on the hitch. Farther back, less weight on the hitch. Adding 200 pound 1 foot in front of the axle will add almost nothing to tongue weight.
I know you understand this, and I'm really not being picky, just expanding on your point for general information.
For anyone thinking more weight behind the axle to reduce tongue weight is the answer, no, that is a terrible idea as well.
Here is a video demonstrating the effects of trailer weight distribution.
A agree the op situation is too heavy, and that the propane/batteries are almost full weight on the hitch, but like I said just clarifying for other that not all weight in front of the axle equates to hitch weight. It may not be relavant to the OP situation, but lots of other will read tses posts instead of posting their own questions and giving them as much info as possible is a good thing.I post in general terms when answering questions. Yes, I am aware of weight placement over the axle, in front of the axle and all the way forward toward the hitch point.
But to explain that to someone who is not familiar with hitch/tongue weight and how its measured is really being "picky".
In general terms, given what the OP posted and the weights given, it is safe for me to say that without a doubt, the tongue weight would be way over the 750 lb limit. Was just trying to put it into terms that would be easily understood.
I could have just as easily not posted anything about weights and advised him to "go for it".
This is exactly why you need to weigh your loaded trailer so you know where you stand and can adjust weight distribution if needed. You also need to consider the location of holding tanks and the effect that they have. Towing with them empty is always best but partial can cause sloshing issue that can lead to sway.A agree the op situation is too heavy, and that the propane/batteries are almost full weight on the hitch, but like I said just clarifying for other that not all weight in front of the axle equates to hitch weight. It may not be relavant to the OP situation, but lots of other will read tses posts instead of posting their own questions and giving them as much info as possible is a good thing.
Also like I said, I know you knew this, it really was for others, and no, not being picky.
But $$$$$$!https://www.airstream.com/travel-trailers/bambi/
i am biased, but the video has a nice 5g ranger lol. id say the ranger is a good match for most of the Airstream line up to about 25 foot.
https://www.airstream.com/travel-trailers/basecamp/floorplans/standard-16/
I like this one in the X model so its a bit more adventure ready.
trouble is Airstream is so darn expensive for the amount of space.
VIN: | 4X4TRPV21NB029499 |
Condition: | new |
Year: | 2022 |
Manufacturer: | Forest River |
Model: | RP-202 |
Floor Length: | 25' or 300.00" |
GVWR: | 6485 lbs |
Payload Capacity: | 1911 lbs |
Sleeps: | 4 |
Slideouts: | 1 |
Dry weight: | 4,574 |
Hitch weight: | 485 |
Furnace BTU: | 20,000 |
AC BTU: | 13,500 |
Number of Awnings: | 1 |
Awning Size: | 12 |
Thanks. I like this much better too. The cost is more. But manageable. I'm thinking around 1500.00 for the brake control install and the WD hitch. Thinking 1000/10,000 rated WD one.Much better choice. As long as you load it keeping items as light as possible, you'll be ok. The lower initial hitch weight gives you some "wiggle room" as to carrying "stuff".
It will also allow you to carry some heavier items in the truck bed without going over the gcvwr.
Your still going to need a wd hitch set up, so figure an extra $500-$600 plus for a quality set up, and of course a brake controller.
You don't want to go too heavy with the wd hitch.. the bars need to flex a bit...going too heavy or "stiff" is just as bad as too light a set up. If it were mine, I'd probably go with a set up with 750 lb bar rating. Figure after you load your rig the tongue will be around 600 lbs, maybe as high as 650, as the storage compartment is up front and you'll be packing it.Thanks. I like this much better too. The cost is more. But manageable. I'm thinking around 1500.00 for the brake control install and the WD hitch. Thinking 1000/10,000 rated WD one.
Good point. Thank you!You don't want to go too heavy with the wd hitch.. the bars need to flex a bit...going too heavy or "stiff" is just as bad as too light a set up. If it were mine, I'd probably go with a set up with 750 lb bar rating. Figure after you load your rig the tongue will be around 600 lbs, maybe as high as 650, as the storage compartment is up front and you'll be packing it.
