The Dreaded Water in Spark Plugs (TSB 21-2147)
Ohwell
Minnesota
2023 Ford Ranger XLT FX4
The engine cover is not needed to keep the water out , a piece of foam pipe insulation does a much better job ...
Thanks for posting this, I went on an 80-mile round trip in the rain today, and when I got home checked the ends of the tube and had moisture on one end. I used 1/2 inch pipe insulation I found at Walmart.
Gizmokid2005
Gizmokid2005
GA
gizmokid2005.com
SQL Developer
Just talked to the dealership, they have managed to figure out it is covered under warranty. I should have a $50 deductible, but it sounds like it might be waived? Either way, free or $50 is in line with what I was expecting. They're still waiting on the engine cover showing up which is still supposed to be here today.
What a debacle.
kendive
Ken
23 Ranger Lariat Tech Pkg Tremor
Yeah, I'm less concerned with the engine cover, more with the fact they're basically telling me to get bent.
That is sad. One reason I don't understand giving ford more money for an ESP when they don't honor it.
Gizmokid2005
Gizmokid2005
GA
gizmokid2005.com
SQL Developer
They probably got wind of the forum here and knew they were overmatched , see if you can get them to wash it ...
I know that corporate also sent them a bit of nasty-grams about this having supposed to be covered under warranty, so I think that helped.
ylwjacket
N. GA
2019 XLT FX4
I was At ACE Hardware today, and bought a piece of 1/2 insulation to put in there.
OrangeStreak
New Mexico
Good idea! I have an Engine Cover but will add this in addition. Is that insulation 1/2 inch ID or OD? Thanks.
OrangeStreak
New Mexico
what is the ID size on the foam cover and what length did you use? Thanks.
On mine, I used 3/4 inch inside diam. split pipe insulation. Just cut the length to what you want...I cut mine to fill the straight area between the "humps" that protrude.
The split stuff comes with a "sticky" adhesive on the edge s of the cut...peel the protective film off and it will stick, especially on the top....make sure you clean the plastic cowl real good with a cleaner and wipe it down with some isopral alcohol so the sticky will stick.
Ohwell
Minnesota
Inside diameter, there is also tape you can use if you peel the plastic layer over the tape away, it's not a necessity to use the tape because the bottom side of the foam will kind of latch-up behind the rivets and hold itself in place. For length I went from about the middle of the two bump-outs on the seam (27 inches) so it wouldn't drip on anything electrical. I also plan on adding the engine cover.
DranC
Drandon
Florida USA
2023 Ford Ranger XLT SuperCab
Healthcare Corp Analyst
Anyone know whether the standard cover installed will clear my catch-can?
OrangeStreak
New Mexico
Assuming that the sticky adhesive is on the ID to hold it onto the plastic seam in the truck? Where did you buy the foam?
OrangeStreak
New Mexico
Does the tape come on the insulation itself or does it need to purchased separately?
Assuming that the sticky adhesive is on the ID to hold it onto the seam? Where did you buy the foam?
Sticky is on the edge of both horizontal cut edges so it will stick to itself when wrapped around a pipe. The adhesive isn't real "sticky"...kind of like the stuff on a band aid.... just made to stick to itself, but it works well. Been on mine for several months. Cheap enough to replace often if needed.
Lowes/Home Depot carries it in the plumbing section....just a few bucks for a 6 foot length.
