Livernois Tuning released
CO2Ranger
I wanted to ask if the standard soft shift 91-93 tune adapted to anything in tow haul mode?
i know a lot of truck tuners provide dedicated tow mode tunes for turbo charged applications where a performance tune would not do well.
Tow-haul mode and Sport mode still perform similar to what they normally would. Tow-haul uses engine braking to maintain speed on downhills and reduces gear hunting. Sport mode holds gears longer, etc.
Only difference is now you have more power to work with. Hope this answers your question.
Livernois Motorsports
Dearborn Heights, MI
2019 F150
Ok I guess @Livernois Motorsports Anthony and the tuning gurus were looking out for me today! I just got the email that my tunes are ready! ??
Gotta say the service being talked about in this thread is spot on! Not even 24 hours after sending my stock file! I'll followup tomorrow with my first impressions...
Thanks for the shout out, glad to see we were able to get that taken care of for you so quickly!
What do you guys have to say about splash blending a gallon of E85 in a tank of 91 (CA E10) to avoid knock? Especially in hotter weather. 18.9 gal tank
Recommend? Stay away? Indifferent?
Would like to hear your thoughts ?
Edit: @Livernois Motorsports also thoughts on Boostane and Torco Accelerator please
We strongly suggest against the use of any additives in the fuel such as octane boosters or race fuel concentrates. Ford also mentions this in the owners manuals as well. Boosters have been found to cause issues long term with build up / residue as another has mentioned on here that can make internal parts get a rusty colored type of coating. They can also cause harm to catalytic converters, o2 sensors, plugs, etc. These trucks are designed for use with fuel ranging from E0 to E15 so it wouldn't hurt to add a small amount of additional ethanol into the mix if I had to pick between the two.
R_B
Thanks very much for sharing those tech tips with your ISP / router also!
commbubba19
Omaha
2020 Ranger XLT FX4 - Gots mods
Network Engineer
Right, just wanted to make sure it's safe to tow with the tune. When towing you don't want to throw high boost, advanced timing under heavy load. Hence why diesel guys get a tow tune vs a power tune etc.
CO2Ranger
I believe Livernois recommends switching to their tow tune for heavy or prolonged tow use, but tow/haul mode on a performance tune is fine for shorter, easier tow usage.
Since it doesn't take long to switch the tunes and they give you so many, I wouldn't hesitate to swap them a few days before I planned to tow.
DMVRanger
Tyler
2020 Ranger XL 2WD
Server
If you have any extra "truck" money...I would recommend the Pedal Commander! I had it on before my tunes came in and it alone made a big difference. Combined with the tune it is great!
On the pedal commander website they only show 2011 ranger compatible devices, never had one before but could you show me where you got yours?
ShawnYZ250F
Shawn
Las Vegas, NV
2020 Ranger XLT
Retired US Air Force, Defense Contractor Now
Use the search drop downs at the top of their page. It will bring up the PC18. The Ranger isn't listed in the description but all the other Fords are. There was a discount you can try "PC20". Two QDs and its done. I didn't set up the bluetooth and just use the city setting. I did try the sport and sport +, this truck runs very well with the stock tune and the PC! I like the Livernois tune too but I could be happy with just the PC installed.
DMVRanger
Tyler
2020 Ranger XL 2WD
Server
Interesting, correct me if I’m wrong but the pedal commander essentially adds more “modes” to my truck. Like D and switching to S. Not an unsafe thing just changes how the car will feel and respond? So the pedal commander changes the “feel” while the tune (Im running a livernoise 93 performance) actually goes into my trucks code and changes when and how it performs ? So added on top it would again just be more “modes” and a different “feel” but no real preformance increase even while “feeling” like the response and stuff is quicker? Hope I Understood that correctly
That's correct. The commander adds zero hp/performance just a more responsive pedal with different modes. This is a good option for those who don't want/need more power (why wouldn't you ? ) but just a more responsive pedal. But for a couple hundred more you can have a tune that really wakes this 2.3cyl up.
2019 F150
We do also offer our LME Throttle Enhancer for most of the current Ford , Lincoln 2008-2020 model year vehicles and have another version for Chrysler vehicles as well. Our throttle enhancer also includes the gain adjustment knob included standard where as most companies charge a premium for the adjustment feature. Using top quality, USA assembled manufacturing, fully digital processing, and OEM quality connections our Throttle Enhancer is designed for reliability, and durability that your vehicle deserves.
https://www.livernoismotorsports.com/product/LPP690401
geophb
Mechanical Engineer
You can program the throttle control directly within the tune itself. Pedal commanders or anything similar is 100% a waste of money In my opinion.
It gives the illusion of responsiveness/power by putting a "gain" on what the ecu sees the throttle position sensor doing. Pushing the pedal further will have exactly the same effect.
Pinepig
Charlie
Sacramento
Last count was 12
lol
Big props to Anthony and Livernios. They were able to get the tune(s) to me before the 3 day weekend and now I get to play up in the Sierras all weekend with MORE POWER. I did take it for a spin around the block real quick and even with my camping stuff in the bed it's a very noticeable power improvement.
So sweet.
First Responder
Fred
Southern California
2020 Ranger STX, 2011 Ranger XL
The tuner from Livernois worked great, it took out the skip shift and shut off the engine kill at the stop light. I also was able to calibrate my speedometer for the 33's, I checked it with the speedometer and a radar speed trailer. The tow tune worked great with 89 octane, I will have to check it with 91.
As soon as someone comes out with a LSD I will install lower gears, the stock carrier has the ring gear welded to it. I will have to ask Livernois if they have a LSD for the Ranger.
bluetruck
Ma
2020 Ranger
Hey just curious, what did you set your revs to for the 33s?
Pinepig
Charlie
Sacramento
Last count was 12
lol
Put about 300 miles on it up in the mountains the last 2 days ( we got chased out by some serious smoke ). I loaded in the 91-93 soft shift, to put it in one word, superb. Damn it's smooth, holding gears when it needs to, swiftly and softly rolling through the gears when it needs to do that. I'd have paid $500 just to get the tranny to shift that well. Anthony, give the guys that sorted out that programming an atta boy ( or a raise :clap: ). beautiful work guys. The extra power passing folks is handy too, was reeling a guy in in a newish F150 uphill with all my camping gear in the back trying to pass a Prius in one of the way to few and short passing lanes on Hwy 88 on the way home. Even got a nod from the guy when we went by him on the next one.
Earlier on Saturday before the smoke rolled in.
