Are My Tires Still Safe?
NeptuneRanger
Scottsdale, Az / Carlsbad, Ca
2019 Ford Ranger XLT
Insurance Agency Owner AZ, CA, CO and WA.
No... call around and see if someone will squeeze you in earlier. If you have to ask, deep down you know the answer. It isn’t only the blow out scenario, but general loss of control on slick roads. If you have prior knowledge of a potentially dangerous situation and you drive anyway and subsequently hurt someone else you are negligent. By posting these photos you have documented your own case. Horse is out of the barn now. However you manage it, get new tires ASAP
HenryMac
Mech. Engineer - Retired
I just went out and checked the air pressure in my tires ahead of a trip I've got coming up and I saw these cracks in the tread. The cracking is kind of uniform throughout al of the tread and tires. Sidewalls look good. Stock Duratrac FX4 tires.
As @ATGC mentioned, those aren't Duratracs, they are Dynapro Hankooks.
Here are some photo's of the Hankooks on our Ranger that has 17,000 miles. No cracking at all like your tires have.
Cost isn't an issue. Timing is. I leave at 3 am Thursday morning. I just checked around and can't get an appointment until the 5th.
Gotcha.
Perhaps you could get an appointment at your destination? That way any risk would only be half the trip. I've had to work preventative maintence in on long road trips before due to mileage.
Hopefully you're right! (Also, anonymity is not promised or provided by any internet forum.)
Do you think you could sue the crazy dude on the corner who said the world was ending because you spent all your money on hookers and blow?
Or could you sue forum members who endorsed a particular tuner because said tune blew your engine?
The answer is no. No hope needed.
grizzly
New Jersey
2019 Ford Ranger Lariat
I'll need a closer picture of the tread to determine what to do.
and I'll need a quarter also....................
CHS
chris
Crossville, TN
(Ruby) 2021 Ford Ranger Lariat 4X4
I need no shit useful answers.
Don't you just love those that feel the need to type anything just to make the day go by??
I found this for you. Most likely too late. That said, They are tiny cracks. Just go to work and bring it to a tire shop ASAP. I' sure they have been there for a while now so the chances of an immediate blow out is small (IMHO)
What Causes Tires to Crack in the Tread?
While tire sidewall cracks are more common and unavoidable, cracks in tire tread are a potentially urgent concern that drivers need to address. In most cases, a crack in the tire tread develops first on the sidewall, and then moves to the outer part of the tire, going underneath the tread. Tire tread cracks can also indicate dry rot underneath the tread that could lead to the tread blowing off the wheel entirely, which can put the vehicle at risk of losing control on the road.
Cracks in your tire treads need to be examined immediately. Given the thickness of this part of the tire, the crack likely indicates an underlying structural issue that could put the driver and other vehicles in danger.
Glocker
Glocker
Boca Raton
Hey all.
Yeah. I don't know why I typed Duratracs - I was shopping those for replace tires. I have the Hankook Dynopros.
I think my last off-roading trip is what caused the issue. There was a very long length of trail that was shale, and I only aired down 10 lbs. My tires were actually over inflated at the time to 35 lbs. So they only got aired down the 25 lbs. on the trail. I'm thinking that shale was rough on the not-aired-down-enough tires.
I'm going to drive the Ranger up to work today and get one of my friends at Fleet Services to look at it and give me a pass or fail.
When I saw the potential issue last night I went into panic mode because I pretty much knew there isn't time to get this fixed. No-one has tires in stock for same day installation!
This is my opportunity to get 27570R17 tires installed when I get back though!
I've got about. 25" of tread on these and I'm still above the wear bars.
Reactions: CHS
Ranger54
Ben
Northwest Arkansas
2020 Ford Ranger Lariat FX4
Service advisor
Hey all.
I think they look fine. Those look like battle scars and not tread separation. But as a service advisor, I’m suggesting 4 new 275/70R17 tires just in case. ?
MoldyTaco
Steven
Salt Lake City, UT
2020 Ford Ranger XLT
College Professor
Just a thought here. I do not know your trip route but you might consider a shop on the way that can get the tires in and install them in an hour or so.
As for appointments, they may not have one available but most places take walk-ins. If you explain your situation they may squeeze you in. You might have to leave it with them until after work. You could just by a coworker lunch for a ride back to work and a ride to pick it up.
Personally, if there is any doubt in my mind I would replace them but that is just me. Good luck and safe travels.
KNI
Finland
Ranger Raptor 2021
For short term your tires maybe safe, but for long term no.
A look at your tires indicates that they maybe dying to old age. If that is the case they most likely will not blow up in short term, but their ability to stick to the road and stop is already degraded.
You can check the age from DOT mark. Usually 5-7 years (+2 year shelf life) is enough for any tire.
https://www.oponeo.co.uk/blog/tyre-s-date-of-manufacture
RANGER_MARC
MARC
Delaware USA
FORD RANGER LARIAT 2019
TEACH
If you are asking the question, "are my tires still safe," then it is time to replace the tires. Why gamble your life (and, potentially, those of other drivers and passengers) to avoid postponing a trip? Wait until you have four new ones and then take the trip in safety. Happy trails!
Glocker
Glocker
Boca Raton
Couple of problems. There is no postponing this trip. It's a funeral that was delayed by COVID. Also, no one has my dam tires in stock. So They can get me in, but they don't have tires to install. Ughhhh.
On the plus side, the fleet manager where I work says send it. He said my tires are nearing the end of their service life but the cracking is not deep and the tires have some miles left to them, but not much.
