34” Tires Are a Go!
Andy
Andy
Decided to try and fit 34” tires since there wasn’t a clear answer on here.
The truck is lifted 3” in the front and 1” in the rear. I replaced the intrusion beams with BDS intrusion beams and clearance is perfect. No rubbing from lock to lock and no rubbing under full articulation.
Truck is setup with the icon stage 5 kit and BDS extended shackles on icon 17” wheels
Attached images of a stock Ranger for comparison.
THLONE
Thom
Tucson,AZ
internet wise guy
What was the power loss? Larger tires create a lower numerical final drive ratio.
Andy
Andy
Andy
Marginal at most. I’m running an e50 tune now so it’s still pretty quick. Biggest difference would be the feeling from starting and stopping. Rolling acceleration isn’t noticeably different from my feeling.
Andy
Andy
Andy
do you happen to know the offset of the wheel? looks really good
Here are the full specs:
  • Size: 17x8.5"
  • Finish: Titanium
  • Bolt Pattern: 6x139.7mm
  • Backspacing: 5.75"
  • Offset: 25mm
  • Hub Bore: 108.1mm
  • Load Rating: 2750 lbs.
awelzel
Andrew
Midcoast Maine
2019 Ford Ranger XLT 302A Supercrew in Black
Where did you get the milestar patagonia 295/75/17? I can not find them anywhere only 295/70/17. Also do you think the 1" lift in the rear helps fit the tires in there or do you think these tires would fit without that lift in the rear?
Andy
Andy
Andy
That's my fault, I put 75 instead of 70. I had been going through so many tire sizes that day I was probably mumbling sizes in my sleep haha. I bought my 295/70/17's off amazon with free shipping for $697.
As for the 1" lift in the rear, I don't think its necessary however you will need to have the front end at least 2.5-3" lifted to fit the tires with some room to clear. Once you lift the truck 2.5" in the front it is level but any higher and you will have the front higher than the rear. I went with the 1" in the rear to leave room for twist off road which I cant speak to without the lift. So I would do a lot of measuring on your end before you buy the tires. Off set wheels are required as well.
Hope this helps!
NJ
2019 Ford Ranger 4x4
Truck looks amazing. I love it. I had to do extra work just to make my 33’s fit on a Rough Country 3.5 in lift kit. I ended up running factory 17’s, bought inch and half spacers for the front and cut the crash bars.
fusseli
EE
@Andy you and I use the same dealer, they did that work? I am probably going to have them put in the Fox / Ford Performance 2" level
Andy
Andy
Andy
I did all the installs myself on my truck but I’m sure they would do it for you. I used their stock truck for comparison hah.
RngrRegmnt586
Roy
So Cal
2019 Ford Ranger Fx4
Would anyone happen to know if I could run 34" tires on 17x9 +0 offset wheels? I have the BDS intrusion beams already. Just need to cut the original crash bars and install BDS beams. Also wouldn't even mind ditching the beams all together.
