10r80 dead. 110k miles. Ford sucks
Swede726
Brian
Connecticut
2020 Supercab Sport
Self Employed
If you get a used truck with the Ford Gold certified pre owned warranty, its 7 years/100K miles on the powertrain. This is what is keeping me from doing a transmission pan/tune... If/when the 10R80 takes a dump, I want no question as to warranty coverage.
Yeah. My 2020 supercab was cpo gold and I have been looking into the tune. I assume if you buy the Ford tune and diy they can possibly not honor the 7/100 transmission warranty? I did read you can easily revert the truck back to stock with the tuner. So I guess if you start having issues you can just go back to stock before you send it in.
Superspirit
earth
22 ranger
They will know by the key counts that it was just flashed. If not willing to take the risk, then don't. But you won't get away with cheating.
Ford can tell if the ECM has been flashed, how many times and how many drive cycles since it was flashed. Probably even when. So no fooling them if they want to check.
Langwilliams
Langley
Lorain, Ohio
there are piggy back tuners that don't leave a footprint (to my understanding). They connect between the manifold pressure sensor an the ecm (I think) an just trick the computer by telling it it's getting a pound or two less (or what ever they set them for) so it adds more boost. there are stages for these so I assume they add more depending on the fuel you're using. You can remove it in a few minutes for a trip to the dealer service dept.
I have looked at these because the ford tune is the only one available for my bronco. I liked the Livernois tune but I guess no one has cracked the bronco security.
ctechbob
Shawn
2020 Ranger XL/FX2/STX
Adult Daycare
Couple of caveats here.
Yes, I know Gale is talking about Diesels, but in-line gas tuners do work similarly. (As you said, modifying sensor inputs).
I'm not saying all the in-lines are bad, but for me, I wouldn't use one.
I do wish Banks would do one of their tuners for our gassers.
HardRock
USA
Long story short
Valves sticking, "skipping" on clutch. Local dealer recommended new trans.
$10880
No rebuild quote. Asked for one. Waiting on that call now.
Took truck in for trans slipping, bucking, faling out of gear behavior I didnt know was an issue until after I left. Told them I needed fluid and filter and probably some diagnostics. 3.5hrs later as I'm paying for the fluid change, tech mentions that I "should bring it back in for diagnostics. Nothing changed."
I got pissed and passive aggressive and left a Google review. Was given a free loaner while they had the truck for diagnostics ans told that Ford and the dealer would work with me on a solution.
Got the call today with info at the beginning of the post, was told that Ford coverage ends at 100k. I'm livid.
I can't afford 11k for a new trans. Shit, I can't afford half that. That's why I have a ranger not a 150...
What are my options? Help?
landiscarrier
Landis
Pocono Mtns Pa
2025 Ranger Raptor
Sales
Keep in mind.... Magnuson-Moss Warranty Act (MMWA) requires a car manufacturer to prove that an aftermarket part (or tune)caused damage before denying warranty coverage. I think a few Google searches will show that there have been issue with the transmission tuned or stock. My 2 cents.
Colo_Ranger
2021 Ford Ranger XLT FX4
This is a double edged sword. Yes, they are required to prove it but they also have a legal team on staff who will make your life unbearable. They won't roll over because you said so. They will fight the legal battle and deny it until you give up. What are you more likely to do? Spend $8,000 on a transmission or $50,000 on a lawsuit.
MyLittleRanger19
MyLittleRanger19
Andrew
Princeton, TX
2019 Ranger STX
Electrical Engineer
Ok everybody.
Finally got a real number from local dealer.
5800 for rebuild out the door.
It's not horrible. Local shop was just a couple hundred under that and I'd rather have the work documented by the dealer so when it dies again they already have the history... lol
Ill be swapping the pan for one with a drain at the next fluid change. Then I'll personally keep on top of the fluid changes.
Gibs45
Redondo Beach
2021 Ford Ranger Sport 4x4 Cactus Grey
Sales
Nice, updated CDF drum as well?
Ok everybody.
