Jeffsmith13
- First Name
- Jeff
- Joined
- Sep 3, 2020
- Threads
- 4
- Messages
- 71
- Reaction score
- 296
- Location
- Clever, Mo
- Vehicle(s)
- 2020 Ranger xlt supercrew 4x4 iconic silver
- Occupation
- Railroad engineer
still have the crash bars?Just put on a set of 35x11.5x17 Toyo AT3’s. Fitment is perfect and no rubbing upfront.
3.5” lift in front 2” in rear. Wheels have +25 offset
sweet mod to the stock rims. love itDidn't go as daring as others, but haven't seen anyone else with this size so thought I'd throw in for reference.
Old tires: Stock 255/70/R16 Bridgestone Duelers
New tires: 265/70/R16 Falken Wildpeaks (+0.5" same size as stock 17")
I dig the look more than I would have thought. Might not even upgrade to a 17" wheel, currently running the base level steel wheels rattlecanned matte black w/matte clearcoat.
Dude this truck looks great, lift, wheels, tires. I'm considering 275/65 r18 vs 275/70 r18 with a stage 1 fox 2.0 lift on my 2020 ranger fx4. Grabber atx tires.Installed the new Toyo Open Country AT3s, 285/70/17 C with Icon Vector 6 wheels today. BDS intrusion bars replaced in front of the wheel, but the rear-of-wheel intrusion beams are stock. No rubbing with ~1" clearance in front at lock and ~1/4" in back.
Side note: will be selling the stock 18" set in San Diego.
Are you saying the largest with or without a suspension (1.5" or 2") that you would go 275/65 r18??Based upon what others have said regarding clearance issues with stock wheels and stock ride height this is what I’ve come up with for the 17” and 18” stock wheels. At modest 1.5” increase in height and .4” increase in width for both tire upgrades.
I think I meant stock ride height but I ended up with 275/65R18s (Falken WildPeak AT3W) tires on mine while adding the 2” BDS leveling kit. And then at a later date Icon tubular upper control arms to correct a slight camber issue that would ultimately cause uneven wear on the outer tread of the front tires.Are you saying the largest with or without a suspension (1.5" or 2") that you would go 275/65 r18??
Thanks...
This is awesome. A man after my own heartIf anyone is interested, I have attached a Excel spreadsheet that I use when sizing tire I want to use.
I have protected the "Tire Sizes" tab so you don't shot yourself in the foot in the first 2 minutes of use.
If your really like a sore foot, the password to unprotect it is "Wheels".
How this is useful.
I agree - looks about perfect, you got any overall shots of the truck?I've had a few questions since I posted in the off-road pic thread so here's my setup.
I'm running BFG K02 275/70/18s (~33") on stock rims with the Bilstein 5100s on the highest setting. They are suuuuuper tight but so far no rubbing even after some mild off roading in Moab.
Here is how far I am from the knuckle:
I can just about get my fingers in-between the knuckle and the tire at it's closest.
The stance is near perfect in my opinion.
Here's my crash bar tolerance. This is driver's side, full right lock at the front crash bar.
Here is the rear crash bar, still on the driver's side, but full left lock.
I'm sure if I got to full compression, I'd have some rubbing but I'm fairly convinced this is the absolute biggest you can go on stock rims with a level.
