Tire Size Fitment Master Thread
alaska2baja
Redondo Beach, CA
2020 Ranger XLT SuperCab, 2008 Yamaha TW200
Adventure Guide
New to the Forum and just read through this ENTIRE thread...The configuration I am considering is a set of the Fifteen52 Analogs in the 16 x 7.5" / BS 4.25" / 0 Offset size. Mounted to a set of General Grabber ATX 235/85/16's. Will also be adding an ICON Stage II kit adjusted to 2.5 (level) in front and 0-1/2" lift in the rear. I'm fairly confident I will not have a rub issue but my concern is with POKE. I do not want the tires to stick out beyond (or much beyond) the fender. The tire is tall and narrow 31.7" x 9.3" but the rim is only offered in 0mm offset. Can someone check my math and advise. Cheers
ironman2991
Kyle
Utah
'19 Ranger XLT
Aircraft Mechanic
I've had a few questions since I posted in the off-road pic thread so here's my setup.
I'm running BFG K02 275/70/18s (~33") on stock rims with the Bilstein 5100s on the highest setting. They are suuuuuper tight but so far no rubbing even after some mild off roading in Moab.
Here is how far I am from the knuckle:
I can just about get my fingers in-between the knuckle and the tire at it's closest.
The stance is near perfect in my opinion.
Here's my crash bar tolerance. This is driver's side, full right lock at the front crash bar.
Here is the rear crash bar, still on the driver's side, but full left lock.
I'm sure if I got to full compression, I'd have some rubbing but I'm fairly convinced this is the absolute biggest you can go on stock rims with a level.
ddtcm81
tc
nc
f150
armed service
Just put on a set of 35x11.5x17 Toyo AT3’s. Fitment is perfect and no rubbing upfront.
3.5” lift in front 2” in rear. Wheels have +25 offset
still have the crash bars?
Verhiz
Evan
Arkansas
2020 Ford Ranger Lariat FX4
Private Security
I tried to find the info on this, so if I missed it I apologize. I am installing the Eibach 2.0 coil overs and shocks. The front lift with be at 3” and I’m putting 1” blocks in the rear. I’m trying to find the largest size tire I can use and not have to use spacers. I’m looking to have no rubbing and full articulation. I have factory 18” rims. I’m also installing BDS upper control arms if that helps. Thanks!
hkusptac
Teo
Creston
2020 Ford Ranger FX4
Didn't go as daring as others, but haven't seen anyone else with this size so thought I'd throw in for reference.
Old tires: Stock 255/70/R16 Bridgestone Duelers
New tires: 265/70/R16 Falken Wildpeaks (+0.5" same size as stock 17")
I dig the look more than I would have thought. Might not even upgrade to a 17" wheel, currently running the base level steel wheels rattlecanned matte black w/matte clearcoat.
sweet mod to the stock rims. love it
Doog Bigner
Pittsburgh Pennsylvania
2020 Ford Ranger XLT FX4 Black pkg
Director of Community Relations
Installed the new Toyo Open Country AT3s, 285/70/17 C with Icon Vector 6 wheels today. BDS intrusion bars replaced in front of the wheel, but the rear-of-wheel intrusion beams are stock. No rubbing with ~1" clearance in front at lock and ~1/4" in back.
Side note: will be selling the stock 18" set in San Diego.
Dude this truck looks great, lift, wheels, tires. I'm considering 275/65 r18 vs 275/70 r18 with a stage 1 fox 2.0 lift on my 2020 ranger fx4. Grabber atx tires.
Verhiz
Evan
Arkansas
Private Security
Im dying to get my hands on some stock steel wheels!
Doog Bigner
Based upon what others have said regarding clearance issues with stock wheels and stock ride height this is what I’ve come up with for the 17” and 18” stock wheels. At modest 1.5” increase in height and .4” increase in width for both tire upgrades.
Are you saying the largest with or without a suspension (1.5" or 2") that you would go 275/65 r18??
Thanks...
Randy2400h
Randy
2019 Ford Ranger Lariat Sport FX4, 2015 Ford Edge Sport
Thanks...
I think I meant stock ride height but I ended up with 275/65R18s (Falken WildPeak AT3W) tires on mine while adding the 2” BDS leveling kit. And then at a later date Icon tubular upper control arms to correct a slight camber issue that would ultimately cause uneven wear on the outer tread of the front tires.
PltFX4
Richard
Minneapolis, MN
2019 Ranger Lariat FX4
If anyone is interested, I have attached a Excel spreadsheet that I use when sizing tire I want to use.
I have protected the "Tire Sizes" tab so you don't shot yourself in the foot in the first 2 minutes of use.
If your really like a sore foot, the password to unprotect it is "Wheels".
How this is useful.
EJH
Ed
Subarus, 2021 Ranger
How this is useful.
This is awesome. A man after my own heart :) Thanks for sharing.
I will be modifing to support 17" also.
Oregon Comrade
Portland, OR
2019 Ranger FX4
I agree - looks about perfect, you got any overall shots of the truck?
