Oil Filter Access Modification
ctechbob
Shawn
2020 Ranger XL/FX2/STX
Adult Daycare
Lots of folks hate those stupid little plastic screw inserts that hold the cover on to access the oil filter, and for good reason, they suck.
If you're not opposed to opening up the 3 holes very slightly with a step drill, you can install these GM Style fasteners:
On my 2wd truck, there is nothing behind the holes to get in the way, but if you choose to go this route, double check. I'm not responsible if you chew up a wire harness. Folks in the salt belt would probably want to put a little paint on the metal afterwards, or some form of protectant.
Now it's just a simple twist to take the rubber shield off.
Link to the fasteners I purchased:
https://www.amazon.com/dp/B0BD8DWG5C?psc=1&ref=ppx_yo2ov_dt_b_product_details
I've replaced mine with rivnuts and thumb screws. I believe Ford did this on later model years.
ctechbob
ctechbob
Shawn
Adult Daycare
Pretty much anything is better than the stupid things Ford installed on mine from the factory.
They're ok for about the first two times, and then they're shit.
RAYJAY
UNION DALE PA
just do the magnets .... super easy ......
gryder
Garrett
2019 Ford Ranger Fx4
You mind sharing a picture of the access with the thumb screws or a link to the ones you used? I picked up a rivnut set and this sounds like my next project.
ctechbob
ctechbob
Shawn
Adult Daycare
For those of us that don't care for the magnet idea.
ppfd
2021 Tremor
RN/Paramedic
Dealer changes in mine so I guess they replace them when they break them
Stic-o
Lake View Terrace, CA
I just leave all the tabs off. the flap will tuck in and doesn't move. Easy-peasy!
JohnnyO
Jon
Pittsburgh, PA
2020 Ranger STX 4x4
meistreguy
Guy
Killeen, TX
2019 Ford Ranger STX
Great idea!
_TraMor
TraMor
Upstate NY
22 Ranger Tremor, 17 Focus St, 97 Escort Wagon
IT by day, shade tree Mechanic... also by day
What keeps the magnets attached to the liner?
Nothing other then magnetic force is needed.
I saved some bucks and used old enterprise class hard drive magnets. There is absolutely no way these things will come off accidentally, I've even used the same type of magnets to hold my coat to a filing cabinet.
