10R80 transmission poll.
Have you had your Ranger in for transmission repairs.
  • Total voters
    275
Skyy
Skyy
Idaho
None
Stevedbvik1, Thanks for the tip on local parts.
_TraMor
TraMor
Upstate NY
22 Ranger Tremor, 17 Focus St, 97 Escort Wagon
IT by day, shade tree Mechanic... also by day
Okay, I had mine replaced at 19k. Like many on here the trouble began with a cold start and either first or reverse feeling like the parking brake was engaged, it wasn't. Brought it into the dealer who dropped the fluid out and found chunks. So, in June of 2024 I think, the transmission was replaced with a new unit. It's been okay so far but I'm still at under 10k and on occasion shifting is wonky and generally exhibits issues like it had prior. I do have an extended warranty through my insurance, Geico, which... I mean... might be snake oil, but we'll see how it pans out. I'm to a point in my life that I'm doing anything I can so this will be my last "newer" vehicle.
Being in the rust belt sucks so bad though, every chassis I come across is one death wobble away from being a driver holding a steering wheel sliding down the road on the seat rails.
Lcr3000
Craig
Alexandria
Ranger Tremor
IT Engineer
Yeah, I’m going there
This is to try to get an actual feel for the percentage of forum members who have actually had to have transmission repairs / replacements ( warranty or not) as compared to those who have never had their Ranger in for transmission related issues.
We often read that it’s only a small percentage of owners who have issues resulting in repairs or replacements. Hopefully this sheds some light on that claim. Thanks for participating
I definitely appreciate you thinking of this. Good idea. My is being overhauled based on the TSB 23-2250, as I type this.
caniwi
Aaron
Vancouver
2021 Ford Ranger Tremor
IT
I got 21 tremor. I had rough shift 3-4 but otherwise reasonable. I put 33" skinny tires on and i didn't like the 1-3 shift as it revs high and then bogs down a bit when driving for economy in the city. at 45K km (~28k mi) i dropped pan and it was fairly dark and filled with some lubeguard in it. I think my shifts were 30-40% better. I then bit the bullet and paid for unleashed tune. It now shifts 1-2 (a bit firm if going slow, fine if 10%+ throttle) but the harsh 3-4 shift totally gone right after loading the new programming and changing nothing else.
I'm quite convinced after many many hours of reading that a bunch of the harsh shifting is the CRAP programming on this transmission. The fluid change early i'm sure helps a lot and ensure any bits floating around get out of there and gets some fresh lubrication. The programming unleashed does for smooth shifts was good insurance for me. Driving around with constant hard shifts cant be good for any tranny. Ford is programming them for better MPG regardless of longevity. That's my thoughts on it. I hope i did the work early to save my transmission. There is obviously some factor of what one you got on assembly line, but that + fluid change + programming has to make a long term difference!
Skyy
Skyy
Idaho
None
A couple years ago, Frod came up with a programming change to boost horsepower up to 300 for the ranger. I wonder how many people had that done that also had these tranny issues earlier in mileage rather than later.
wayhipcat
Pasco WA
2019 Ford Ranger FX XLT Crew Cab
School Psychologist
2019 Ranger, bought at the end of the year. No transmission issues. I installed a PPE pan at around 35K. Currently have 58K miles.
Ranger_Rocks
Wandering
Wanderer
Have you tried driving in Tow/Haul mode ?
quangdog
Kimball
Meridian, Idaho
www.youtube.com
2019 Ranger Lariat FX4
2019. Roughly 65,000 miles. Have not had to do any transmission repairs, but I have taken several preventative measures:
1) Installed a soft-shift tune from Livernois. This alters the shifting strategy from stock.
2) Added an aftermarket deep pan with extra capacity and cooling fins along the bottom.
3) Drained / filled when adding pan. Repeated drain fill once more about a week later.
4) Added Lubeguard at last drain/fill.
5) Installed FitzStick so I can keep my eye on trans fluid level.
So far I have not had any real problems. When the truck was newer, on colder mornings it would have some pretty rough shifts because it was underfilled from the factory so it needed to warm up some before it would shift smoothly. This is no longer an issue with the above measures taken.
I voted No, but I do wonder if I would have had to vote Yes if I'd not taken the above measures.
Lcr3000
Craig
Alexandria
Ranger Tremor
IT Engineer
I think the change happened in September '22. Mine was built in June '22 so,,, ⏰️💣
However,,, at 23k I haven't had any issues. It shifts really well since I got it tuned.
Here is the tech in this link explaining it quickly.
10R80 Repair
Cmar
Cam
Australia
Ford Ranger PX
Medical Scientist
Currently? Nobody.
My complaint with Ford is not that they didn't handle the issues, just that it required an awful lot of weeping and gnashing of teeth to get them to cover something that was a very well known and documented issue.
All the manufacturers seem to be having issues right now, but not all the manufacturers are turning a blind eye to their customers.
That's because they are all following the same mantra, make it faster, lighter, cheaper. (but then charge more for it)
stringbreaker
washington state
2019 Ranger XLT
How many miles? Symptoms before it puked? Towed to the repair facility?
At about 28,000 it started with delayed/hard shift from first to second only when it was below 40 degrees. All last summer it was fine all the time. In late September on colder mornings it started hard/delayed shifts again and in 3rd to 4th as well. Took it to the dealer they said it needs to be either rebuilt of replaced. Took it in Nov. 11 still waiting on the warranty company to approve the work. I stupidly did not extend the Ford warranty since I had purchased the add on warranty when I bought the vehicle. When I do get it back if it even hiccups it's gone. Too bad because other than this it's been a dependable rig and it looks better than anything else on the market. I drove it to the dealer
JohnnyO
Jon
Pittsburgh, PA
2020 Ranger STX 4x4
It's a shame that Ford won't take the time to look through these forums, too really get a feel for how their customers feel when these problems arise. Just my two cents.
They do but they don't respond.
JohnnyO
Jon
Pittsburgh, PA
2020 Ranger STX 4x4
Normally I'd be getting a new one about now but it's been trouble-free and they quit making Supercabs and I'm not ready to give my long bed.
caniwi
Aaron
Vancouver
IT
Yes i did try that, but i just upgraded to a nice truck and didn't want to have to press the tow button every time i wanted to get in and drive. Also it makes the revs go higher before shifting and holds gears longer which wastes gas. Keeping the truck for the planned 10 years, i might save close to enough gas to justify the tune. Now with the tune it feels like what the truck 'should' have been like and i can enjoy it.
woodworker
Joel
virginia
2021 Ranger Sport
I remember that commercial.
