10R80 transmission “stuck” between gears
ccasanova22
Lakeland, MN
2022 Ranger XLT Tremor
Good evening,
My 2022 4x4 Tremor with stock tires and gearing has developed an interesting transmission issue: it seems to get “stuck” between gears at times and no amount of throttle (gentle application or heavy throttle) seems to get it out of this state until the trans decides to apply power again.
Originally I had very hard shifts when cold, neck snapping and unnerving (almost like you got hit by somoene) but a complete “lack of power” is something new that’s cropped up.
At 5-10mph, rolling through a neighborhood, the unit sometimes acts like it’s not even hooked up to the drivetrain, which is dangerous if you have to cross an intersection. The “slip” has now lasted for many seconds and even up to 5-10 seconds while the software (assuming Torque Management) appears to be “limiting” until it can figure out what to do.
What follows is either a hard shift, no shift at all until the next lower gear “catches” due to slowing down from coasting, or a proper re-engagement into gear.
This doesn’t happen when warm, only in the first 5-10 miles of driving.
Has anyone had this exact issue before?
BettaRanga
NC
Are you using Sport mode? Are you accidentally hitting the manual shift buttons on the shifter? If you tap these twice it goes into manual and can appear to be stuck in a gear.
Tim H.
TJ
Maryland
2020 Ranger Lariat 4X4, 2016 Corvette Stingray
REALTOR
Good evening,
Have the dealer check your fluid level. Sounds like it’s under-filled.
Good evening,
we sure have brother. mines at the dealer for it now. several threads about it around 5g. apparently ford has a new pcm update to address the issue. however, if your trucks being doing this a while actual mechanical damage could be an issue and not just a computer thing. good luck.
ccasanova22
Lakeland, MN
No, I do not use Sport mode. Even then, if you tap the shifter + or - it would show a gear selection on the display.
My 10R80 is actually stuck between gears, as in it tries to shift and the revs go up but the shift doesn’t complete and the computer pulls timing so the throttle pedal has less of an effect while the truck coasts/slows down.
It eventually finds a gear but holy cow, it takes many seconds which is not normal.
It's not a fluke and it will not work itself out...get it fixed while you have warranty...
It just took mine a whole city block to regain propulsion, but went away when warm, so I’m going to have to leave it overnight at the dealer so they can diagnose on a cold start as it doesn’t do this when warm.
mine behaves better when warm also but was gradually getting worse where even the down shifts were jerky.
