What oil will you be running after your 1st oil change?
Floyd
illinois
What about the other 2 ounces missing? Do you not pull out the measuring cup to get the extra 2 ounces in?
Closer to a cup!:rolleyes: I keep an extra quart on hand and add eight ounces of it with each Oil change.
I know that's about an ounce too much, :giggle: but the bottle is marked in 8oz increments.:like:
OrangeStreak
New Mexico
I am running Motorcraft SAE 5W-30 Blend and a Motorcraft filter.
Stronglight
Rex
Los Angeles
21 Lariat FX4 Supercab, rear seat & decal delete
Does anyone have an oil filter wrench they particularly like or recommend? Thanks.
ctechbob
Shawn
2020 Ranger XL/FX2/STX
Adult Daycare
No, no I don't. The truck doesn't use oil or or add gas, so in 5000 miles it is sitting exactly where I left it and I don't stress it.
svogt302
Parsippany, NJ 07054
Before retirement, I worked as a fleet mechanic for Mobil Oil,
We had access to a corporate lubrication department which provided us with expert advice on every lubricant .
For my personal vehicles I have run Motorcraft oil and have never had a part which ran in oil show any wear. Of course oil change intervals have increased as oil has improved and as fuel management has improved.
I will use Motorcraft parasynthetic 5W30 in my new Ranger .
It meets the highest standard in the industry.
I have been cautious about extending oil change intervals so I'll probably be conservative and change oil every 4000 miles. I may even hand my used oil down to be used in some older cars as I have in the past.
When asked about oil change intervals I usually respond with this question....
What sort of underwear do you wear??
After the incredulous look on their faces I continue...
Whether you wear cotton , synthetic blend fabric, or the finest silk,
they still get the same skid marks!
Mobil 1 Is as good as it gets, but it honestly won't provide any greater protection than Motorcraft, Especially if you think you can run it after it is contaminated.
Motorcraft parasynthetic 5W30 meets SN+ standards,but moreover it meets ILSAC GF-5 standards. AFAIK there is no higher standard for gasoline engines.
Another point... oil service life involves a lot more than the number of miles, and so oil change intervals should be done based on other factors as well, with the mileage arrived at after those considerations.
ILSAC GF-6A, GF-6B
Fitzmotor
Gold Sponsor
Saugus
Retired from Honda Racing.
When I was at Honda we tested a lot of different oils, (I dont think Motorcraft though) run the engine on the dyno for 500 miles and analyze it, up to 3000 miles.
Mobil 1 was the best, the protection additives were still active, some oils were done by 500-1000 miles.
We were looking for best power and wear protection, Mobil 1 did not make any more power like some of the other oils, but it lasted the longest.
A 2.2L V6 turbo was used for testing.
Okinawa Joe
2013 Boss 302, 2022 Ranger XLT/Splash/FX4
Vintage Japanese Motorcycle Shop Owner
I'll run the Mobil 1 extended mile, gold stuff in it like I did my Focus ST, 5000 mile changes. And I ran that car like a scalded dog, never used a drop. Good stuff, I traded the car in with 100k miles, still ran perfect and I ran a Cobb stage 2 tune with a mountune big intercooler.
My Boss 302 gets Amsoil signature 5w-50.
lou5560
Louis
New Jersey
2019 Ford Ranger XLT FX4 Off Road
I always used Mobil 1 Extended Performance but they were out of stock so I tried Valvoline Extended Performance full synthetic oil. I actually like the Valvoline. My 2019 Ford Ranger seemed to run quieter & smoother. The price is better too plus I change my oil every 5000 miles so I may stick with the Valvoline as it is more readily available in my area.
neat1954
Tulsa,Ok.
2022 XL Supercab FX4
What oil comes in the new ranger and what do they put in at the dealership if you dont specify anything?
Floyd
illinois
ILSAC GF-6A, GF-6B
Thanks for the update....
Time marches on and so do oil ratings. I retired some time ago and seldom read the fine print on a trusted product.
You are correct and Motorcraft 5W-30 Synthetic Blend motor oil does meet the latest GF-6 standards,as well as SN Plus and the new service designation SP, which are the relevant standards for the U.S.
Desert_5G
Eric
Arizona
Tacoma
Motorcraft semi synthetic
Rick V.
NE Ohio
06 Scab,63 Fairlane, 22 Scab XLT FX4 302a
Fleet bodyman
This is the one I like, it fits the Motorcraft and the filters that Amsoil uses. I got it at Advance auto.
Stronglight
Rex
Los Angeles
Synfulz
Richard
Philippines
2020 Ranger FX4 Diesel :)
Retired Powerplant Operator
The Ford required as to keep within warranty. As someone stated if you do not have a record of regular oil changes per requirement and have a engine failure then the dealer can just say maintenance was not being kept up. So dealer oil changes for me, at least until the warranty runs out.
