What are you guys towing?
Arly
Arlyn
Houghton MI
trails maintenance
One of the joys in living in the sub tropics, we can can camp all year round. Although mid summer can get a bit hot, depending on where you are.
Huuummn, we ski all winter in moderate temps. Then in the summer we camp without AC. We also don't have AC in our house either. What is the advantage of living in those sub tropics?
reidmefirst
Reid
Des Moines, Iowa
2021 Ranger
Computer stuff
Good points, I found when towing our 2400 Kg loaded Caravan (Travel trailer for you guys) it wanted to sway a bit around 100KPH with passing trucks etc. I discovered travelling with the front water tank full and the rear one empty made all the difference, tracks straight as as arrow. Who would have thought an extra 80 odd kilos further foward would have made such a dramatic difference.
Yar, today I towed the setup across town to its winter storage. I moved a bunch of the heavy tool bins to the front of the boat, dropped the hitch another pin on its little adjustable range hoping that more tongue weight would make a smoother ride. It was still a little scary, but I think I can blame this firmly on the wind: we had wind of 30mph gusting to 50mph (50-80kph for the aussies in the crowd), mostly as a cross wind while I was towing today. Add to this, one of the wheel bearings was getting 'pretty warm' after just 5 miles of driving today, so I think replacing it will be on the winter work list.
I backed the boat into its storage unit just as the rain started, which is great because boats hate to get wet ?.
Pinecrestjim
Pinecrest, FL
Finally getting to tow with my ranger after owning it a month. I hauled out my sailboat and took it around some highways.
It was a great first test for the truck: the boat ramp is 9 degrees/15% grade, the boat+trailer weighs ~6300 pounds currently, and for extra fun the lake is 3 feet lower than normal so the bottom of the boat ramp is not as good as it usually is. For the haulout I 'cheated' and used trail control mode: put the truck in 4 low, set trail control to 5mph, and let the computers do the work going up the grade. The 15% grade climbs about 150-200 feet out of the lake valley, then flattens out. It was no problem for the ranger.
Today we dropped the mast, and I hauled the boat over to a CAT scale. That meant some highway driving (in traffic) and a little driving on the Interstate.
Early opinion: it was a little more scary than when I drove with the rental Uhaul. The haulout was a lot nicer, for sure -- the RWD uhaul (Silverado/Sierra trucks) was really not fun getting up that ramp. The ranger felt a little more squirrely driving at highway speeds though. Part of this is not having the tongue weight right currently (only ~300 pounds on the tongue today, which made for squeaking tires any time I wanted to move). Probably I was running that way with the uhaul pickups the last few times, but the bigger silverado/sierra is a little more forgiving. The trailer only has hydraulic surge brakes which is also not ideal. And there was a fair amount of traffic today, doing the normal stupid things cars do around tow vehicles. The rig did sway a little above 65 at one point. Usually my setup would start to way above 70mph on the Silverado so was ready for it. We had high winds today, I'm sure that contributed -- wind was 20-30mph.
Anyway, overall quite pleased with how this 'midsized' truck handled the load. Hopefully next season I'll get electric brakes on the trailer/brake controller on the truck, the package will be a bit lighter, and I'll have a better handle on how to load the boat for proper tongue weight. I guess my mini-review of Ranger towing is: it handles quite well, but when you're getting near the max towing capacity of the vehicle you really want to make sure you're doing everything you can to have your trailer setup right. A bigger truck lets you be a bit lazier with that stuff. All in all this is what I was expecting when I bought a ranger, though. I'll just be towing around the midwest, so no real elevation change, and kinda thought a full-size truck would be overkill for that...
If your tongue weight was only ~300# by the CAT scale on a 6,300# trailer rig, you were running less than 5% on the tongue. You were taking a huge risk with that light a tongue, especially if trailering over 50-55mph. When you rebalance and get the tongue weight closer to 10-12%, which with that trailer weight will be close to the Ranger's max receiver weight of 750#, you'll notice a much more pleasant towing experience.
Deleted member 1634
If you guys are driving down that old RR grade, or as its called today the Bill Nicholls Trail, be sure to get a permit. We need to have a trail pass to be on it and they do ticket people for not having one.
Okay, I wasn't sure. I tried to find something about that a few days before when we were thinking of doing it. Nothing I could find was clear on if you did or not. A lot of contradicting statements saying you need a pass on all trails, except for some where you don't, but it didn't give a list either way. But I'm sure I missed something.
Arly
Arlyn
Houghton MI
trails maintenance
I can't speak of other trails but the Bill Nicholls you do. I'd guess all sled and atv ones you would. We buy one of those all trail passes (whatever they're called) so I guess we are safe on the Bill Nicholls Trail. But if we drove our 6x6 on it, how would they check?
Chriswlbr94
Mesa Arizona
2021 ford ranger stx
Machinist
Hey all, new 2021 stx owner here. I was planning to tow my 4 seater rzr and was wondering if there were any additional coolers (like the ppe) that I would need prior to towing? It'll probably be about 2500-3000 pounds total including the trailer. TIA
No coolers available and none are needed. Factory setup does just fine, and what your gonna be towing won't put any strain on the factory system.
I tow more than twice your estimated weight with no problems at all.
Hook it up and enjoy.
raytwntrvlr
Raytown, Missouri
2021 Ranger XL
We had a great time in the U.P. with our Ranger pulling our Winnebago. Stayed a few days at Union Bay at the Porkies, hiked some by the Lake of the Clouds, then went over to Muskellunge Lake S.P. for a week so we could take in the sights on the east side of the U.P.
13,000 on the truck now and nothing but easy towing and good times.
raytwntrvlr
Raytown, Missouri
2021 Ranger XL
Lake of the Clouds in the Porcupines. Get there sometime, if you can. Lots of great hiking and beautiful views. This year was the best color we've ever seen. Maine/Vermont has nothing on the U.P. this year.
Arly
Arlyn
Houghton MI
trails maintenance
I'm shocked and saddened, you didn't stop by to say hi.... :crackup:
maxbottomtime
NE OH
2021 Ranger XLT SCAB 4x4
What model boat do you have? I have an early Catalina 25 that is a heavy son of a bitch. paying the $500 premium to have someone else haul, store, and launch was definitely worth it to me. I've always had to use tow straps to launch because the trailer was effectively a cradle mounted to a flatbed that needed 4'+ to float the boat.
reidmefirst
Reid
Des Moines, Iowa
2021 Ranger
Computer stuff
Mine is a S2 79. Weighs about the same as a Catalina 25, actually. The standard weight of mine is supposed to be 4250, but with all the stuff onboard it weighs in at 5000 currently. Mine has a lifting keel so it'll float in a bit over a foot of water, makes launching and retrieving a lot easier.
You might look into a tongue extension, there is a Capri 25 that launches with one (it has slightly deeper draft than the normal 25) with no issues. Our ramp is steep though: 15% grade that continues to the dock, so the dock is 12 feet deep only a couple of feet from the ramp.
But anyway depending upon the weight of your trailer, the 5th gen Ranger should tow yours just fine.
maxbottomtime
NE OH
very nice! Is your keel weighted? That’s the biggest regret I have on mine. I’m in freshwater but the 1500lb keel pin failing would put her on the bottom quickly.
Mine is a first model year - they overbuilt them, loaded with gear, outboard, etc north of 6000lbs.
No tongue extension would have been long enough - I used a 20’ tow strap. At any rate, I just pay for haulout and will hopefully be onto something much newer, much larger soon.
