SYNC Will Not Update
joroberts240
Jerry
Brenham Texas
2020 Ranger Lariat
The last software update I was able to perform on my 2020 Ranger was in December of 2022. Since then, when I connect to WiFi, the search for updates button will not work. I have the automatic update feature set as well, but that does not seem to work either. Is this a known issue?
gtyates
Greg
Ranger, Explorer, Sport Trac
Manager
You may be better off to log into the Ford owner site and download the Sync update to a USB this time. It sounds like your last update must have left off something which is why the search function is not working. Also, you have to be connected to a Wifi network, but I assume you knew that. :)
Billythekidd
Willyu
Mine was doing that as well... I noticed in the settings that the modem number was not displaying. I pulled fuse number 9, put it back in and the modem came back... then the updates worked.
Glocker
Boca Raton
Any benefit to updating the non-Nav (big screen) Synch in my little screen Ranger?
Figarou
^^Yup, this is exactly what I did.^^
I couldn't get any updates over wifi. After I did the Sync update using USB, getting the update over wifi started working again.
You are going to notice a lot of updates using wifi. Keep checking for updates because it'll also update your maps.
It took me several days because I didn't start the engine. I turned on accessory mode, did a few updates, and then shut everything down to charge up my battery with a trickle charger before it gets to low.
@joroberts240
Sharky
Keith
PA
2020 Ford Ranger 2015 Ford Focus 1934 model 40
I also had to use the USB update method. could not get it to update at all trying WIFI.
ylwjacket
N. GA
2019 XLT FX4
so, if you're one of the lucky ones not having an issue with the current sync, is there any reason to "upgrade" to 23188? Does it add anything or work better? Current one is fine, and I'm afraid to upgrade and create problems.
joroberts240
Jerry
Brenham Texas
2020 Ranger Lariat
Thanks all.
Going to do the USB update and see how it goes.
BTW, in your experience, how long should an update over WiFi take? In the past I would connect to the WiFi through my phone to perform an update on my drive to work (which is an hour) and it seems to take several attempts.
PltFX4
Richard
Minneapolis, MN
2019 Ranger Lariat FX4
Thanks all.
I second Cynlabs method. Just did 3.4.23188 this past Monday (from 3.4.23088) via Cynlabs. For a NON-nav update I would thing it would be quite quick. With Nav, the download to the USB drive is ~15 GBs, so depending on your internet connection speed, just the download can take a while. Once done, the in the truck portion on mine was ~34 minutes...
A note here: With this update, the Bluetooth connection to my phone was lost; so had to re-pair it... no problems afterwords.
Phantomfixer
Florida
2021 Ranger Lariat FX 4
If you're happy with what you have don't update.That 23188 update is a blessing for me since I had several issues that were fixed by it.There's nothing new there...just fixes
Jedadiah
Jed
Central Kentucky
Former '21 SuperCab Owner
The times I've had Sync issues are when it has updated itself over WIFI. I leave that option off, but it has updated itself once despite that. It updated itself once and I lost all connectivity features for a time. A thumb-drive update fixed it. Without Nav, an update with a thumb drive takes about 15 minutes.
