Tire Size Fitment Master Thread
Sma1986
Shane
USA
2019 Ford Ranger XLT/FX4
I can confirm that 265/70R18 on stock wheels fit with the Eibach Pro truck coil overs with no rub, no crash bar mods and no wheel spacers.
Eibach's were install straight from the box no adjustments made.. reported as 3" i failed to measure before lift..
I went with Falken wildpeaks at3w. Set at 35 psi.
Little noisier than the Hankooks im now selling.. also have a vibration.. which might be tires too..
Nice, I just bought the RTR Tech 6 Ranger wheels (+30 offset) with 275/65R18 General Grabber AT/X tire should be here within 2 weeks or so. cant wait
DrizzyDrake
Drake
Calgary AB
Legacy GTB, RX7 FD, soon buying a ranger
Technician at Subaru
Anyone else have 275/70r18's? Saw Ironmans post and just want to see other trucks with that size. Debating if it's too much or if it looks fine. (I do plan to flex offroad though so it will likely rub good)
Nathan289
Nathan
9 Mile Falls, WS
2020 ranger lariat fx4, 2019 mazda cx3, 1963 falco
Leo
That the size i wanted to run, but i chickened out.. went with 265/70r18s.. i think they would have fit but it wouldn't take much to make them rub.
Sma1986
Shane
USA
I think i would of went with that size if i hat stock wheels but since i got the RTR wheel with +30 offset i am good with a wider wheel witch i like better for stance
350toRanger
New York
2020 Ford Ranger XLT
Thanks for the replies everyone. I removed the plastic cover as suggested and it helped until I had the level kit install. The Ranger is looking nicer now.
I love your wheels! I've been looking but haven't found anything just like them. Can you tell me what they are and where you got them?
ironman2991
Kyle
Utah
'19 Ranger XLT
Aircraft Mechanic
Hey, so have you removed/replaced the front and rear crash bars yet? Have you started rubbing a lot more lately? Just curious, because your truck has a nice stance and the 33’s must be nice for offroading. Im planning to go this route you have setup.
Update on my rubbing; I found the culprit. So the issue wasn't the diameter of the tire (still haven't rubbed on or removed the crash bars) but my offset. Since I'm on stock wheels (low offset), I am rubbing on the frame (about where the oil filter is, but on both sides) at full lock.
Since its winter I haven't done any off-roading lately so your mileage may vary if you chose a different suspension/tire combo and start flexing. However, when I did Gemini Bridges in Moab (a pretty mild trail by Moab standards) I didn't rub on the crash bars.
I will admit that the the motivation behind my level/tires was looks and marginal off-road improvement. The stock FX4 is very capable on its own, but the most I plan on tackling off-road is some forest roads and the occasional overland style trail in Moab. I think my setup, with the exception of a better wheel offset is the perfect balance of stance and function for my needs.
Jrel209
Wa
2020 Ranger XLT crew cab
aww i see, i just checked it out and it looks like both 18” wheels from ford have a +55 offset, damn that’s a lot.
t4thfavor
Chance
Eibach's were installed straight from the box no adjustments made.. reported as 3" i failed to measure before lift..
Is this an illusion, or is your truck now "Reverse raked"? I want to go with a smidge bigger tire, but I don't want to go the full 3" since blocks in the rear are not an option for me, and I won't be able to afford an entire set of replacement leafs before I'll need tires..
Sillyguy96
Matt
Canada
2020 Ford Ranger
Are you able to take a picture of your clearance with the crash bar? I have 265/70R18 Falken Wildpeak sitting at home, waiting on the rims to install. But I'm super nervous about rubbing.
Nathan289
Nathan
9 Mile Falls, WS
Leo
Parked on a slope..
Nathan289
Nathan
9 Mile Falls, WS
Leo
I'll try and get pictures when i can get home.
With the Eibach coil overs and 265/70r18s i can turn lock to lock and get my fingers between tire and crash bars..
Bthomas5456
Brian
Arizona
2019 Ranger Lariat FX4
I just had some bfgoodrich all terrains in 265/70s installed on some icon vector 6 and they rub the front and rear crash bar.
Jrel209
Wa
Nice wheels. What are the offsets? I wonder if the further we get away from stock (+55 for 18") the more chance of rubbing? I'm kind of new to this wheelfitment, but thats what i'm noticing, anyone with more exp able to confirm?
Nathan289
Nathan
9 Mile Falls, WS
Leo
Nice wheels. What are the offsets? I wonder if the further we get away from stock (+55) the more chance of rubbing? I'm kind of new to this wheelfitment, but thats what i'm noticing, anyone with more exp able to confirm?
Thats what i noticed when researching what fit and what didnt..
Id get 4 out of 5 fit xxxx size tire..
The one guy that didnt fit would have wheel spacers or different off set wheels.
Have someone sit in the truck and turn the steering wheel lock to lock and watch the outside edge of the tire to crash bar.
Now visualize that tire being pushed an 1" or 1.5" further out and swinging through the same arc as before.. its now closer to those crash bars..
I also think larger diameter wheels will allow wider tires as the spindle tappers inward..
Downside is less sidewall for airing down..
It's just as @Nathan289 says - here's a picture to show you just how it works. The horizontal bars represent your crash bars - the shaded tire in the RHS pic represents where the tire is moved to with the change in offset. You can see how it hits the crash bar.
EDIT: Updated photo to inlcude 0mm offest wheel not turned.
