Pics of 285/70/17 tires
MTBranger
Stefan
Austin, TX
2020 Ranger XLT FX4, 1994 Miata K-swap
Design Engineer/ Racecars
Could one of you guys that is running 33's without any rub do a measurement from center of fender to center of wheel for me?
I got mine mounted and I'm just barely rubbing the felt liner and mud flaps in the back of the well with the bars out. Going to raise my Fox coils up more but didn't want to guess at how much more I needed.
The
Wheels there will do it!!! I'm not sure what your offset is but it is doing the job for sure!! I myself am running factory wheels with no spacers and only touch the sway bar at full lock!!!
Z_randall
Zach
Murrieta, Ca
2021 Ranger XLT sport
Hello all, I just ordered some method 704 17/8.5 and 0 mm of offset. I am looking to run a 285/70/17 KO2. I have a 2.5 inch rough country leveling kit on the front. Does anyone know how much rubbing I may encounter? Will I possibly need to remove the crash bar or replace them with the aftermarket ones?
NvrFinished
Shea
SoCal
2020 XLT 4x4 Rapid Red
With that offset, you are definitely going to need aftermarket crash bars running that size tire.
NvrFinished
Shea
SoCal
Do you have a recommendation on which one to go go with?
From all the reports here, only the stock wheel (+55 offset) with 285/70R17's will clear with the stock crash bars with a 2.5" lift. Even then, some tires won't clear the knuckle and people ran a 1/4" spacer to clear. BFG's have been confirmed to clear the knuckle.
Wheels with a +20 to +30 offset are known to work well with aftermarket crash bars. Many with 0 offset wheels had to remove their crash bars completely.
I would suggest reading through the Tire Size Fitment Master thread to get a better idea of what works with the various offsets and tire sizes.
BladeRanger
Bladimir
Escondido Ca
Ranger 2020 XLT FX4
Electronic Engineer
Here's mine, I have a 295 /70R17 with 0 offset, the bars are deleted and the plastics block behind the front tires is gone as well, I cut the felt liner but you don't have too, some of the guys here can chime in. The plastic block has 4 screw at 13mm. I had a bit of rubbing on the fender flare and I'm going to shave that off a bit
I’ll say it again. You’ll rub like a Thai masseuse. Crash bars and plastic rear crash block removal are likely necessary. At the least, you’ll probably need aftermarket bars, such as ReadyLIFT, BDS, Fabtech, etc. Taller, wider tires and a bit, or a lot, of poke look great, but it doesn’t come without complications. Prepare for the worst and hope for the best.
Z_randall
Zach
Murrieta, Ca
I’ll say it again. You’ll rub like a Thai masseuse. Crash bars and plastic rear crash block removal are likely neCesar. At the least, you’ll probably need aftermarket bars, such as ReadyLIFT, BDS, Fabtech, etc. Taller, wider tires and a bit, or a lot, of poke look great, but it doesn’t come without complications. Prepare for the worst and hope for the best.
Did you take off your crash bars or go with aftermarket ones?
Is there any reason you picked that one over the BDS one?
It took some research and I really only had pictures from the forum and the Internet to go by. Price was not a factor in my decision.
To me, the BDS appeared to be simply a smaller crash bar that was designed so it could be “angled out of the way”.
The Fabtechs looked very strong but didn’t appear to give the same degree of clearance on the rear bars as the others.
The ReadyLIFT beams appeared to be purposefully designed to accommodate the tire and had an extra “rib” to add strength. It just seemed better thought out.
Your choice will be yours to make but I hope this helps.
Z_randall
Zach
Murrieta, Ca
Thank you I appreciate it!
Z_randall
Zach
Murrieta, Ca
One more question for you, any advice on the removal of the stock ones?
bfastr
Nashville
2021 Ranger Lariat
I just installed the Readylift beams myself, today. they are awesome.
The printed instructions walk you thru the rear beam removal.
For the front, remove the lower valance. 5 bolts on bottom, and a bunch of clips, also some pull pin clips under the upper opening thing. just pull it off the front, then you will see three nuts ( on each side) holding the bumper on. loosen them all. but only remove two on each end, then run the last one out to the end and you have plenty of room to pull the bumper forward and the front bars will slide right out without the bumper falling off.
