ctechbob
No. Higher viscosity oil might be to thick to get through the little nooks and crannies of the engine and actually cause higher wear. Try 5w-40 if you want but I wouldn't go thicker than 5w on the bottom end.
That's not how that works. I guarantee you even a 20W50 is going to get everywhere that a 0W20 would. Not that you would want to use a 20W50 (Or a 0W20).
Engineers pick the oil based on pressure, flow, and the ability to last through the recommended oil change (IE not shear out of grade), with a large dose of EPA Ratings mixed in. Along with 'will this engine survive until the warranty is out with this recommendation?'
You could run a much thicker oil if you wanted, chances are, the engine would last just as long as a 5W30, but things will suffer. Fuel mileage and potential startup wear for starters. Also, should something break, Ford will likely point the finger at the oil, it would give them a convenient 'out' to not pay for the repair, although they would have to prove the oil caused the failure (not very likely).
The fact of the matter is, except in edge cases (higher power output, racing, etc), a good 5W30 will go the distance, even if it tends to shear slightly out of grade.
Now, for those of us that want the engine to last longer, shorter OCI's, better filters, different oils, etc, can probably tack some life onto the end.
Personally, I worry more about intake valve deposits and soot loading in the oil causing timing chain wear. So I've settled on a 5k OCI with a middle of the road synthetic oil.
