Bucking/Jolting- in all gears and very noticeable in all gears HELP!
dtech
colorado
Are you sure that you got the #4 coil seated onto the spark plug properly? That one is especially hard to get snapped onto the spark plug due to having to put it on at an angle due to other devices being in the way.
Hey Bob - any chance you know Ford's strategy for lighting up the CEL and how they detect misfires ? Seems like a high threshold for triggering a CEL, a few engine mgmt system I'm familiar with detect misfires by measuring the cps pulses, another detection method was ionization current monitoring which Saab used. Would be nice to know how Ford detects misfires.
There are numerous possibilities for this and needs a Live Data Monitor for various PIDs when this is occurring.
But with no check light triggering (On) then the Crank Position Sensor is not seeing the misfire, the misfire monitor is not enabled without inputs from the ECT, CHT and IAT1 & IAT2. So, any of the temp sensors can be reading incorrectly and triggering this.
No code misfires are difficult to T/Shoot and requires you to monitor different sets of PIDs to isolate the issue.
1. EGR Related PIDs - mainly focus on what is the position of the EGR Valve
2. EVAP Related PIDs - mainly position of the EVAP Purge vale
3. MAPT - Pressure & Temp Readings
4. CPS & CPS - Sensor readings are they (In Sync)
5. Fuel Trim Data
6. O2 Sensor Data
Being that the tech picked up misfires on Cyl #4, I suspect one of the following in order of probability.
1. Injector #4 - Failing when hot
2. Vacuum Leak - at Cyl #4 port (Intake) of (Head) - (Expanding when hot)
3. Crank Position Sensor losing Cyl #4 position when it's hot
4. Dirty (Intake Valves) (Inspect with Borescope)
As most of the other systems would not just affect cylinder #4, so I would focus on #4 first and branch out from there.
It may only need a (KAM Reset) or more specifically a (Misfire Neutral Correction - Reset) as the PCM may have locked in - This is normal for #4 cylinder
Relative Compression Test - Will help in pinpointing a compression loss via (Scan Tool) by doing a automated test using starter amperage draw (when cranking) you want your readings to be (O) if not at (0) indicates a possible compression issue in that cylinder and then a true compression test can be performed to help isolate (Valves/Rings) or Gasket Leak
Cylinder Balance Test -Monitors Cyl performance and allows injector (kill individually) and you note the RPM drop for each cylinder. This helps isolate an injector issue as a injector kill that does not affect RPM drop indicates an issue with the injector.
Relative Injector Flow Test - This test is automated, and it disables the spark and automatically cranks the engine using a set pressure on the fuel rail and pulsing the injector for a specified time. It reads the ending fuel rail pressure and notes how long it takes for each injector to dispense the fuel from starting pressure to ending pressure. Should be 140ms +/- 15ms
Ref: Test from my Truck for Fuel Injector Flow Test
RangerBill
Here is a link to Ford's 2019 OBD system description. Misfire determination starts on page 20.
https://www.fordservicecontent.com/ford_content/catalog/motorcraft/OBDSM1900.pdf
Simply put, the PCM monitors the crank position sensor for fluctuations in crankshaft rotation speed during each cylinder power stroke.
Ford uses the Crank Sensor, and it can pick up cylinder acceleration speed of each cylinder.
dtech
colorado
the logic used seems pretty complicated seems odd that things like bucking and hesitation doesn't trigger a CEL, have to assume Ford needed to set a fairly high threshold to avoid frequent customer visits to service with a cel. conversely though on high output GDI engines - depending on the cause - doesn't take a whole lot of misfires to potentially inflict some harm to engine.
Washingtonwarrior
Washingtonwarrior
Josh
Washington
2019 ford ranger lariat
Construction
5. Fuel Trim Data
6. O2 Sensor Data
5. Fuel Trim Data
6. O2 Sensor Data
This is all great stuff man and very knowledgeable. I’m going to show the tech this tomorrow and have him do all this . Thanks for the help . Without a check engine light this is not fun. Diagnosis is way easier with one . The more I read about the posts the more I am leaning to a fuel injector but I’ll let you know in know what they say . Thanks again !
ramong
ramon
TX
19 ranger STX
I’ve researched all over online , went to the dealer twice and I will be taking it back after the new year , but if anyone can lead me into some fixes that would be great ..
80k miles ,bucking and violent jolting but very noticeable under load or going up hill. But I only feel it AFTER 10-15 min after the engine is on, when I drive it after a cold start 10 min after warming up it feels somewhat normal to drive. But once it’s warmed up it does start to do this bucking .
took to the dealer and they said it was a EGR valve (seems like a lot of guys had this problem). I told them I would fix this myself , took me 30 min to do .
Problem still exists . I took it back to the dealer and they said I needed to do a KAM reset, the tech did it for me on the spot and then came with me on the test drive and he was like “whoa this is what you have felt?” He then hooked up his laptop for tranny slips or rough shifts and there was no problem .
he then did a ignition misfire test and while driving it it showed cylinder 4 and sometimes 2 were spiking or misfireing.
he said it seems like a ignition/spark plug failure . And told me to replace my spark plugs and coil pack and then if it still has a problem to bring in.
I just replaced my spark plugs yesterday and the problem still exists , the coils get here in 3 days I’ll put those in, but what else would this be?!?!
No Check engine light through any of this btw.
im gonna go look into forscan today and see if anything is there … but i doubt it
Had this problem, ended up being the check ball in the transmission.
It was good for about a month then it came back.
VAMike
2019 Ranger Lariat SuperCab
There are two ways to cut warranty costs: 1) make a product that sucks less 2) pretend the problems don't exist. I'd guess ford went #2 on this one.
Washingtonwarrior
Washingtonwarrior
Josh
Washington
Construction
So I just dropped it off at the dealer and he drove with me for a hour and experienced what I felt . He did a torque converter test and the problem still existed on and off. He did a fuel injector test and it passed . I took a picture of it . He did a crank test and that passed . When we drove he did a cylinder test and it looks like cylinder 1 is the issue more than cylinder 4 . He said he will need to do an air leak test next and submit a ticket to the ford engineer . He did show him all of what you guys talked about and he likes all of it , he is leaning towards a gasket leak ,but won’t know more until he starts taking off parts .
I’ll update when I know more .
Washingtonwarrior
Washingtonwarrior
Josh
Washington
Construction
update - the tech is going to test drive it tomorrow but believes he has fixed it, the fan clutch wire was rubbing on a bolt and causing it to arc, causing to the fan to have a power surge . I guess it makes sense since it only happened when the motor was warm . But we’ll see tomorrow. There’s a rubber bracket that broke off causing the wire to rub on a bolt
Washingtonwarrior
Washingtonwarrior
Josh
Washington
Construction
Man, that cheap hose they use to hold that harness out of the way is sure causing its share of problems!
My fan hoe seems to be ok, but I just doused it with protectant for good measure. I check it often.
FM AZ
Fred
Vail, AZ
2021 Ford Ranger 4x4 Super Cab Lariat, 2005 Mustang V-6, 5-Speed
Retired USAF MSgt, and newly retired Airline Captain
I’d swap it out before it fails. Better to be proactive considering how many issues this stupid design causes when the hose fails, and how easy and inexpensive the fix is. I used a 90 degree silicone hose from HPS.
3/8 Silicone Hose
