Both Leaf Springs Broke
RangerPNW
Thomas
Santa Fe, NM
I can't speak to the probability of both breaking, but $1700 for replacement seems steep.. You could upgrade to Icon, EMU, or even tremor springs for that much.
If Ford is going to charge you for these... yeah then definitely go aftermarket. Hell for that price you could get a nice set of Deaver's.
Zappy
Zappy
Minnesota
Thanks all. It was a clean break both sides. I just took a photo looking up into the bracket on the driver's side - the passenger side looks about the same. I see some rust on the edges but I assume that might be normal for a five year old truck? I'll be sure to get several photos of the break when the springs are removed.
Rp930
Denver
I want to see what the break looks like.
Hell, the sticker's still on there! If that plastic/paper thing and its glue stayed on there, it's clearly a defect. Not wear and tear and abuse, imo. And the bushings don't look distorted.
I bet they might start sweating if you ask to keep the old ones (as @Grumpaw wisely suggested), and they absolutely should give them to you since you're paying for them.
Easy for me to sit here and talk, but you do what you gotta do. If you're handy and have the right tools, swapping the springs out isn't terribly difficult and many here have suggested outstanding upgrades for less than Ford wants.
And calls farther up the chain may be in order because if this is a defect (it sure seems like one), then this is a significant safety issue on many Rangers.
Good luck and please post more pics, that sure is an odd spot for two breaks.
WOW - Clearly a MFG Defect of the springs, bushings appear intact, but even if worn it should have not caused them to break and would have been noted as a popping noise over bumps if worn that badly.
I am going with they were cracked and when lifted off the ground the crack split open due to the weight of the axle.
Very strange indeed.
underwhelmed
GSMs
Retired Military
Chris M
Surprise, AZ
2021 Ranger XLT Sport 4X4
Security Supervisor
I imagine that if a Ford lawyer reads this he is going to lose his ?!
You'd like to hope so, rather than come to know that's standard practice to tell someone to drive it home broken like that.
Langwilliams
Langley
Lorain, Ohio
If you were close to me I have a pair I removed from my ranger in the garage in the scrap pile.
I'd have tremor springs installed for sure if I had it done at the dealer or aftermarket if someplace else.
npspears
Nathan
Ranger XLT
I broke one of my leafs, but I was running jeep trails. I replaced them with wildtrak leaf packs from UK and they're awesome, especially for 300 bucks shipped.
$300!?! Do you have a link or was this a one-off type thing? I'm very interested.
Rocketeer61
Bill
Utah
2020 Ranger STX
That's pretty scary. In my experience there is no such thing as an isolated engineering failure. I'm going outside right now to inspect my springs.
SonoranDesertranger
Stan
Tucson, az
Ford ranger
Emt
Racket
Here and There
2019 Lariat Supercrew 2WD
Transient
From your drawing the break was hidden above where you can see. It would be difficult to detect while the wheels are on the ground or during casual driving.
A defect like this - once the cause is identified - will warrant a manufacturer investigation and I can imagine some lawfirm smelling blood in the water. Be prepared for Camp Lejeune water lawsuit level stuff.
With Fords level of R&D and experience in truck building I wonder if this would be an indictment of the monoleaf design since I think it was unique to the US version of what was a 10 year old truck design. I'm surprised.
I was on the Ebay page where I bought the UK multi-leaf set (they are currently out of them) and they had what appeared to be monoleafs.
Can of worms ? this is...
theprinceofsnj
Richard
Clayton NJ
2019 Ford RangerXL 1959 Edsel Villager 9 passenger
Very strange. I had a 1995 Ranger break a leaf spring. I ordered a new one from Amazon. Had a neighbor install it. (He was a mechanic for Manny Moe and Jack)
The new spring had 3 leaves the old 2. Yes 3 on one side 2 on the other. I think I had that truck about 3 months when I traded my 2014 Fiesta S in on my 2019 XL. My brother who worked on a used car lot sold the 95 for me, about 4 months later.
Grandaccess
Binghamton, N.Y
Computer Consultant
2019 Ford Ranger XL with 47,000 miles. I brought my Ranger in for an oil change this morning. As the mechanic lifted the truck, the forward leaf spring mount holes (sorry I don't know the correct term) broke on both sides and the leaf springs detached from the mounts. I could see through a large window into the service area the mechanic and service desk person looking at the mounts and they called me in right away. While my first instinct was to blame the mechanic (due to the improbability of this happening) it looked like the lift was placed correctly. I searched this forum and the Internet at large and I do not see many instances of a leaf spring failure like this and certainly not both springs failing at the same time. I never carry heavy loads, never go off-roading, and only tow my 14 foot fishing boat to a local lake about six time per year. The Ranger is kept in a garage. I am in Minnesota so I suppose winter time salt could be a factor. Is there a known issue with the leaf springs?
my first reaction was how the hell much did he put in the bed LOL
I have put 1200 lbs, I have been in the air, and most would say I abuse it daily
and you broke both? WTF
