What ball mounts are you guys running?
Lunchbox88
Logan
Missouri, USA
2019 Ranger SuperCrew FX4
I'm thinking of picking up one of those solid aluminum ball mounts for my ranger like this ( https://www.etrailer.com/Ball-Mounts/Fastway/DTBM5600.html ). But figured I would see what you guys were using. Looks like I'm going to need a 6" drop for the trailer I use the most. Also what are your thoughts on an aluminum ball mount? Hoping to reduce the rust and keep it looking nice.
Rp930
Denver
The picture in the reviews of a broken one scares me away from aluminum.
MT19RANGER
JERRY
SIDNEY, MT
My brother and I use this type. https://www.etrailer.com/Ball-Mounts/Andersen/AM3411.html
Lunchbox88
Lunchbox88
Logan
Missouri, USA
I saw that. But looking at the picture it seems it was quite abused. Possible the wrong sized ball shank plus it was torqued down so much it cratered out the aluminum. A data point to look at none the less.
MT19RANGER
JERRY
SIDNEY, MT
I do really like the idea of having the adjustability of that style. Does it rattle alot?
That's why I got it, adjustability and it seems to be quieter than a full steel one.
DHMag
Dale
San Antonio, TX
This what I use. I don't do a lot of towing so I'm not worried about adjustability just yet. If I do get a boat or camper, I'll revisit the ball mount.
Lunchbox88
Lunchbox88
Logan
Missouri, USA
Is the 2" drop enough for you? With as high as my ranger is l think I need a 6". But Im just towing a 10' utility trailer most times.
DrRoger
Roger
Dallas, TX
2011 Taurus, 2019 Ranger XL (May 20)
Here is what I have. I would not trust my 7000 pound trailer to aluminum. It is a 6-inch drop with large ball. If I were planning to tow a variety of trailers that were lighter I might consider the adjustable aluminum. The items in the picture are dedicated to my cargo trailer.
DHMag
Dale
San Antonio, TX
Probably not but like I said, I don't tow often enough to worry about it.
Hi Folks,
No opinion on this other than to understand how they tested the Aluminum drop to obtain these ratings. What material did they use? Heat Treated? How did they conclude 10,000 Lbs rating...If they use the standard testing protocols, then go for it.. Personally, for my towing I would stick with Reese or other name brand products at this juncture. Aluminum just does not have the cyclic fatigue of its steel counterparts, but may be good for towing pop up trailers. Tow my Ranger behind my diesel pusher motor home with this bracket....absolutely not even if it is rated to do so... What is next...composite drops? Carbon fiber is stronger than steel, eh? As one of my engineers, dearly departed now, said...There are two types of plastic in this world...Broken and About to be Broken...
DrRoger
Roger
Dallas, TX
Lunchbox88
Lunchbox88
Logan
Missouri, USA
Hi Folks,
Phil,
I would assume if it passes SAE J684 that its certified load rating should be good to go as long as used within it specified limits? Though not having any specific expertise in materials science or fatigue testing I would also agree steel in general will perform better than aluminum in those situations.
That said I think I think Im going to go with a 1 piece forged steel one like this: https://www.etrailer.com/Ball-Mounts/Curt/C45342.html
Its a bit cheaper and the extra load rating is nice to have. I just hate how rusty they always get.
Hi LB,
I agree that meeting an SAE requirement is a good thing...So then the manufacturer should state this. That gives much more confidence. We, at Ford, could not ever test all conditions of aftermarket pieces, so thankfully, SAE develops these standards. That said, Ford requirements are, in many cases, more stringent than SAE. Aluminum as its place in automobiles, but I hold reserve when it comes to Trailer Tow. Really do not understand why Aluminum would be better as the grander scheme of weight savings as it is minimal for such a small piece, unless appearance is the key driver for purchasing?. Sort of picking the fly $hit out of the pepper IMO.
best,
