What are you guys towing?
We just took delivery of our new Jayco Jay Feather 24RL last Wednesday. (you can google up the specs and compare them to you trailer)
Towing it with a 2021 Ranger, 2 wheel drive, with tow package. Have only towed it twice to get a feel for what might be needed to beef up the stock suspension. Took it up on x-way, ran it up to 65 mph, and it did just fine....just a bit of "mush" in the rear which I expected and should be taken care of with some better rear shocks. Did a 100 mile trip, half on x-way and half down a 2 lane state road.
We loaded it up with our "rv stuff", 20 gallons of water, 2 full 30 lb propane tanks, one battery, clothes that we keep in it, but less food.
But, I am an experienced rv'er, many years, and I feel very comfortable towing with the Ranger.
It will come down to your experience and comfort level. You are going to get various responses, everything from no problem to your nuts for towing something that heavy and long.
SandBaja
Larry
San Diego
2019 Silver FX4, 501A pkg, fully optioned,2012 Rubicon, 2017 Cherokee, 2018 Volt
Almost retired
New to RV's. I wanted to post this RV spec sheet to hear all sides on if it would be safe to pull with the 2022 Ranger (Tow Package, 4x4, OEM brake controller, and WDH). I think my big concern is the Tongue weight and would I quickly go over the 750-pound limit. Any and all advice would be greatly appreciated. I have two adults, two little ones, and two dogs. All combined weight of fewer than 600 pounds. Almost all cargo would be in the RV after that.
I think you would be uncomfortable towing long distance and at speed, even unloaded. The Ranger WILL tow that weight but will get pushed around with every passing truck and at higher speeds you will be white knuckling the steering wheel. The back end will also jitter a bit, possibly correctable with new shocks. Thats with my wife and I + minimal stuff in the back and trailer lightly loaded with 1/3 tank water. I've also towed with a full and empty tank that did not change the tow characteristic much. I'm also using an equalizer WD setup. That's been my experience with a similar sized rig, Grand Design 17MKE.
IMO the Ranger is best suited to a light skinny trailer because the mirrors and above experience. I'm going with a larger truck, as soon as it can be built, that is heavier and built for towing. The Rangers a great truck, just not a tow-er. Others here tow similar and seem OK but I don't feel that. Good luck with your decision and stay safe.
Sir Swivel Hips
Jake
Maryland
2022 Ranger XLT, 2022 Rav4 Hybrid, 2012 Civic
Engineering Technician
Thanks for the input! Glad people like you are giving feedback. Experience is what I'm looking for.
SandBaja
Larry
San Diego
Almost retired
BTW, it tows this great @ ~3500#'s (trailer and SXS), with a fully loaded heavy truck
New to RV's. I wanted to post this RV spec sheet to hear all sides on if it would be safe to pull with the 2022 Ranger(Tow Package, 4x4, OEM brake controller, and WDH). I think my big concern is the Tongue weight and would I quickly go over the 750-pound limit. Any and all advice would be greatly appreciated. I have two adults, two little ones, and two dogs. All combined weight of fewer than 600 pounds. Almost all cargo would be in the RV after that.
I will not say you can't do it, or don't do it, but would definitely advise against it. Especially if you are new to RVs as you stated. That trailer is definitely pushing the rated limits of the Ranger. Even without knowing your family size you will have a hard time staying under the GCVWR and the axle ratings on your truck. Those are the three big ratings to watch. Tongue weight is next, but that figures into the rear axle loading. If you go to this get it weighed so you know where you stand.
Like I said I would not recommend a trailer that size and weight for a first timer. That will be a handfull for an experienced tower in traffic and wind. Not to mention manuvering in tight quarters.
Again if you decide to go with it get a good set of extended/extendable tow mirrors, your going to need them.
Stevedbvik1
2022 Ranger Tremor XLT
Depends on how much you load up with cargo. If you limit what you load up with you should be fine
If that’s a new unit it’s probably pre wired for a rear view camera. That will negate the need for adding tow mirrors. Several good inexpensive options available for camera/monitor setup. We use Tadibrothers and its great
Cabose-1
Eli
Student
To long for my liking, you will have to carry all cargo in the tt.
I have a xlt 4x2 2020
This is my weight as i have it with tunnel cover. My gvwr of the ranger is 6050. So that leaves me with about 1600k payload.
This was my last tow. About 1500lbs cargo to include luggage passengers and tongue weight.
Tow was about 5 to 6k. Dynamics are entirely different than a big giant box tt.
I do not use a wdh. I dont need one.
But if I had a tt, i would use one. Use proper equipment.
I personally never go above 70. No matter how little or big the tow. Always within 60 to 70 mph.
Just tow safe, use proper equipment. Take your time. I am getting old and dont tow at night either lol
Be safe
Good luck
Rear view cameras are great for seeing what's behind you and backing, but they don't show whats along side of you when you want to change lanes. With the stock Ranger mirrors you will still have a blind spot along the trailer.
Stevedbvik1
I have no blind spots whatsoever. Mirrors pick up traffic that also shows up on monitor. Towed all last summer with our Passport and never had any issues.
Stevedbvik1
Passport width with mirrors is 78.6”. Ranger width shows 85.8”. So Ranger mirrors should work even better
Not really sure what you are trying to show here.
Most prewired rear view cameras are mounted on the back of the TT and show what is immediately behind you. The Rangers Blind Spot detection won't work for that wide a trailer and the Rangers are not wide enough to see the sides of the trailer so there is a big blind spot at the rear corners. When you need to lane change a rig that size in traffic you need to know exactly where the back of that trailer is. Believe me a gap that big will get filled real fast. No time to check 2 or three different places.
Tracy Bowman
Tracy
Just picked up our new Jayco 24RL....been on order since last July.
I have posted several times about our plans and the trailer and the Rangers ability to tow something as large...
Well to all you nay-sayers, the trailer came in at 5625 with a battery and 2 full 30 lb propane tanks.
Figure around 6200-6300 with our stuff and a partial tank of water.
As far as towing...I set my WD hitch up and it tows beautifully. Its listed as 29 foot, but its a 24 foot box and 5 feet of front frame. Took it right up on the interstate, hit 65, and it cruises just fine...no sway, no bounce, and the Ranger had plenty of power. Just a bit wibbily/mushy in the back but I think that will be taken care of by a better set of shocks.
Nice!
Stevedbvik1
Have you towed with the camera setup I’m talking about? I have and you’re telling me I’m wrong? Like I said it works great for me and if it wasn’t safe I wouldn’t be doing it.
Sir Swivel Hips
Jake
Maryland
Thanks for the advice. That goes for everyone. Already going to scratch this RV (22MKS). The 186BH Apex Nano seems to bit at least a bit better. Roughly 800 pounds lighter, 4 ft shorter, 7.5ft wide, and 139 pounds lighter on the hitch. Still checks all the boxes that we are looking for. Would you say this is still a stretch for size? Or would that bit of difference make a HUGE difference?
Not wanting to get into an argument, but when did I say you were wrong? I just said I did not understand what the picture you posted was supposed to be showing me. I then went on to explain what my understanding and experience was of rear view cameras, and the Ranger mirrors with a wide TT.
Where is the camera(s) mounted? One for each side? Near the front of the trailer? If that is the case that is not a normal rear view camera setup.
