Tire Size Fitment Master Thread
robotshmobot
Toronto
2020 Lariat FX4
Hey folks. So I've done a lot of searching and have come up with whole a lot of inconclusive. Wondering if I could get anyone with a similar spec's perspective.
I've got a '20 Lariat FX-4 with the BAP 18s. I'm going to level the front with ReadyLift 3" and lift the back with the 1" block. I want to put a set of KMC545 Trek 17x8 +18mm offset on Falken Wildpeak 285/70/R17s.
What's the rub situation here? Anyone with a similar spec?
(how she looks currently)
RangerPNW
Thomas
Santa Fe, NM
You're going to need to need to address the crash bars. I'd recommend the ReadyLift ones.
BGDOGY
Tommy
virginia
2019 Ford Ranger Lariat 4x4 crew cab
I installed the 2.5" leveling kit on the front of my my 2019 Lariat and I'm running 285/65-18 without any rubbing issues once I removed the plastic air dam. Crash bars are intact and my rims are a +30mm offset. The 285/70-18 are about an inch taller, so might rub some. Hope this helps.
Superbj
Bryan
Minnesota
So much information here I feel stupid asking, however many of the posts are customizing your ride for you enthusiasts. I have a 2021 XLT currently with 255/65R17 tires. I bought used so not sure if these were original or if the dealer put cheaper tires on. Anyway I would like to go to 265/70R17 without any lifts, level kits or other modifications. I will also be using OEM 17" wheels with +55mm offset. So will keeping things bone stock other than the increased tire size work without rubbing, etc.?
Colo_Ranger
265/70r17 should work just fine. The door placard will have the OE tire size on it.
theclaw
Chicago 'burbs
2021 FX Off Road
If you haven't already, this thread is a good reference: https://www.ranger5g.com/forum/threads/biggest-tires-no-lift.2458/
The consensus is that 265/70R-18 is the absolute max with factory wheel & no lift, but it also depends on how you're using the vehicle. If you go off-road and plan on flexing out the suspension you'll likely run into rubbing points. In that instance 265/65R-18 or 255/70R-18 would be considerations.
I've been combing this thread and either I have missed it or it's not here.
I have the leveling kit and want to move from the stock 18 inch rims to 17s. I like look of the extra rubber. I've been fiddling with the tire size calculator to find matching combos going from the 18 inch to the 17. Still I can not find the largest size I can fit, going to the 17s, with the leveling kit.
Ideas?
Hickesy
Ideas?
Apparently you can fit a 265/70/17 without a level. With a level you might be able to do 275/70/17? Have you checked this thread? https://www.ranger5g.com/forum/threads/biggest-tires-no-lift.2458/
theclaw
Chicago 'burbs
2021 FX Off Road
Yeah, except I have a lift. If the level kit counts.
CarbonStihl
idaho
HVAC tech
Hey guys, hope I’m not derailing the thread. I just bought a 2019 Ranger XLT FX4. The truck appears stock no suspension lift but is currently running 275/65/r18s. Is this possible or must it have spacers ?
Chris M
Surprise, AZ
2021 Ranger XLT Sport 4X4
Security Supervisor
If that's what you're currently running and there's no rubbing then I guess you're good to go, yes?
CarbonStihl
idaho
HVAC tech
It’s rubs on full turn. Also pinky hardly fits. Wondering if I should downsize or level kit
Chris M
Surprise, AZ
Security Supervisor
Ah, then probably yes to either, whichever is gonna serve you best in the long run.
Colo_Ranger
Ideas?
you can fit 285/70r17 on a stock truck. You get a small amount of rub, at full lock, in reverse. You can solve by removing the crash bars.
That being said: you can usually get a tire shop to test fit for clearance.
The_Kings_apostle
Tim
Georgia, USA
2019 Ford Ranger XLT
Can I put Ranger Raptor wheels and tires on my XLT without modifications or rubbing?
All everyone talks about is how they're gonna either level or lift their truck or use a spacer. I don't want to do any of that so I can't find an answer.
Colo_Ranger
We would need to know the tire size and the offset of the wheel to help with that question. I believe the RR uses 285/70r17 tires, which means they'll fit, but you might have rubbing.
