Sync 3 v3.4 Build 21020
Figarou
How long did you wait?
Did you exit the vehicle for 5 minutes with the key off before restarting?
Yes.
Edit....Ok, it's working now. I wasn't getting a signal.
db_tanker
Darrell
Process Professional
yep took about 30 or so minutes to load into the system. but now its good to go and sirius is up and running as well. android auto is good to go and all functions are there that I normally use.
Bsqrd
Arizona
2020 Ford Ranger SuperCrew Lariat FX4
What version of Windows?
I assume your USB flash drive is formatted for ExFat, not FAT32.
Windows 10: After downloading the zip file, right-click on the zip file>Open With>Windows Explorer
Yep. Used it before. Not a problem with loading just unzipping the file. Fails on the same file, with both downloads. Think the source is corrupt.
GregsFX2Ranger
Greg
2021 XLT 302A 4x2 Rapid Red Black Appear Package
Management
Applied the update. All went well. Requested update via wifi and stated it was up to date.
Sirius didn't operate for a minute or two, but a message flashed stating "Sirius XM Updated".
Doesn't look any different than the previous version. Probably bug updates.
Rp930
Denver
I’m on number 4.
BGDOGY
Tommy
virginia
2019 Ford Ranger Lariat 4x4 crew cab
Did my main update via USB, started it and drove for over an hour. Updating system message disappeared from screen and I had gotten to my destination, so I turned it off. Checked system and it still had the old version showing. Started it again after I got home, took about 15 minutes, said it was done and it would be ready after next restart. Once it was restarted, did the automatic wifi update of the maps, so it's at NA 2 20 now. The maps took about another hour from start to finish. Everything is working, nothing lost, guess it's good to go.
Bsqrd
Arizona
Ok, as they say " Third time's the charm". Downloaded the file the third time and it unzipped and updated. Now Ford won't accept the XML file. Crazy system.
GregsFX2Ranger
Greg
Management
If you have WIFI at your location, connect SYNC to it, then Search for Updates, it will say its up to date and report the successful update to FORD.
huckleberry
North America
2019 Ford Ranger Lariat Screw FX4
not even certain how many nav updates i've kicked off now; maybe 5. it's currently installing 'ced'.
Bsqrd
Arizona
Finally got WIFI working on my home network. Reported I was up to date. It appears that if 802.11r is enabled Sync will not connect via WIFI. When I turned it off on my access point, it connected with no problem. I think I saw an article somewhere about this issue with Ford not adopting 802.11r.
Tom_C
Virginia, USA
System Admin, Retired
I connected mine with 2.4G, mainly because I have a guest network for my wifi home network that is not connected to my internal network. Won't tell anyone what to do, but I don't have anything 'not trusted' on my internal network.
