- Joined
- Aug 24, 2022
- Threads
- 28
- Messages
- 4,565
- Reaction score
- 8,717
- Location
- Midwest - KS
- Vehicle(s)
- 2022 Ranger Lariat-Super Crew, Cactus Gray
- Occupation
- Aircraft Tech
If the Ford alarm is essentially an alarm system there is likely a ground sensing trigger circuit that can be accessed. @airline tech provided some nice details of the inside tailgate lever mechanism and though the CAD design comment may have been something of a joke it's where a bracket to hold a switch inside the tailgate and a contact point would go. Then a lead to interface with the alarm trigger. If the alarm sounds when the door handles are 'checked' when armed it would be easy to chase down. We've already seen that the Ford pass reports alarm events, I haven't looked to see if it does push notifications as well? That should avoid the 'hood ajar' warning of tapping into the hood trigger when driving with tailgate open.
The Factory Alarm uses the Door Ajar circuit, so the Door or Hood has to be opened to trigger.
I tested mine when I first got the truck.
Lock the truck with window down, take keys away from truck and wait (20 seconds or longer - preferably over a minute.
Reach in and using interior handle, open the door - after a 12-second delay the alarm will sound.
Alternate Way:
Lock the doors, take FOB / Keys away from the truck, wait 20 seconds to 1 minute.
And use the Key Blade (ONLY) to unlock the door, FOB not near the truck.
From the exterior handle - open the door - after a 12-second delay the Alarm will sound.
Alternate Way - Lariat (Passive Entry)
Lock the doors and use the (Key Blade) to unlock the door.
If you have the Lariat with the (Passive Entry) grab the exterior handle on the outside of the handle and pull it to open the door - After a 12-Second delay the Alarm will sound.
Basically, you do not want the (Handle) to sense your hand behind the handle (generating- the electronic unlock)
So, a handle check will not set off the alarm, it takes the door or hood to be opened (Door Ajar) to trigger the alarm.
What Bsthroop did was extend the Hood Ajar (Hood Opened) circuit back to the Tailgate.
What we need to do - To get a Handle Check on the Tailgate, tied in, is to find a spot on the latch / handle mechanism to mount a (Proximity Sensor) that will detect movement.
The CAD design comment was a driving force in our new option (Dipstick) aka Fitzstick
It will serve the same function as the external (Microswitch) that Bsthrrop has installed, only moving and modifying his solution some.
This is where we will need to open up the cover and look at the mechanics inner workings of the handle and latches.
Compare Locked - Operation to Unlocked Operation of the handle.
What exactly does not move when locked and what moves?
So, when locked - place a proximity sensor on any part of the mechanism that moves (Handle Check)
The Hurdles to Overcome:
The alarm activates with a 12-Second delay.
So, a quick handle check (MAY NOT) trigger the alarm, as it would be a brief pull and release hey its locked.----Get the screwdriver.
1. Find a spot for mounting a Proximity Sensor - Handle Movement (When - Locked)
Once a spot is found, that will work, find a way to mount in possibly (3D Printed) mounting block for the sensor.
2. Check operation for the input trigger, will a momentary handle check on the Tailgate, actually trigger the alarm (Less than 12-seconds) OR does it have to see a constant (Proximity Away) for 12-Seconds then trigger the alarm. (This is the main factor for proper operation)
Sure, you can hold the handle out for 12-seconds and the alarm will trigger, but that is not going to help in resolving this issue.
3. Wiring is simple, the Hood Ajar Switch is just 2-wires, Power & Ground
The Hood Ajar Switch is a (NC) Normally Closed switch, so when the hood is opened the Ground is broken, which triggers the IPC message and if armed the Alarm.
It uses body ground, and its power source comes from the BCM.
So, for a wire run, it will only need (1) wire to tap into the Hood Ajar switch and (1) wire to a body ground anywhere along the frame.
I am sure this is how @ Bsthroop wired his setup.
