Too close alarm going off
Dokkenmire
United States
2019 Ranger Xlt Sport Supercrew 2wd
I just turn mine off when it does this. Snow, ice, and frost set mine off. Rain disables all the sensors on my work truck, so it could be worse.
Deleted member 1634
I've had blowing snow set off the cross traffic alert when backing out of parking spot before. But to be fair, it was fairly solid looking, so I don't fault it for that.
Only other time they went off incorrectly was when I plowed through the snow bank and they got packed with snow, and again I don't fault it for that. Other than those 2 isolated times, I haven't had any issues. Weird that you guys seem to be having issues so frequently and over such minor conditions.
ed1946
ed1946
elmer
garrison, ky
2015 taurus
Ford fix ??
Sounds like a sour Tacoma troll.
but regardless, the way the sensor functions is to warn you if anything is near it...ice on it, fits that description. so does mud and probably other road grime.
Not sure if all models have it, but there is a button to press to silence them. likely for this very reason.
I keep a can of spray ice remover for this very purpose. if I'm too lazy to even carry out that simple task, the button does the job.
I post a real problem and get a stupid response. Forums are suppose to help people, not sure what your'e doing but trolling. Sensors were clean, was cold out, it seems a lot of people have same problem
Hi Elmer,
I had the same problem, It turned out to be the connector behind the left front headlight not being connected properly...Once seated the problem went away... Might take the truck back to the dealer for investigation....This connector takes a bunch of contortionist body postures to reach.
