WOADKIL
- First Name
- Wil
- Joined
- Mar 25, 2021
- Threads
- 52
- Messages
- 610
- Reaction score
- 1,823
- Location
- Cyber Orange County, CA
- Vehicle(s)
- 2021 Ranger XLT Supercrew Cab FX4
- Occupation
- RETIRED ENGINEER
Ford Superduty Power TailgateOne issue here:
“3. Wiring is simple, the Hood Ajar Switch is just 2-wires, Power & Ground
The Hood Ajar Switch is a (NC) Normally Closed switch, so when the hood is opened the Ground is broken, which triggers the IPC message and if armed the Alarm.
It uses body ground, and its power source comes from the BCM.
So, for a wire run, it will only need (1) wire to tap into the Hood Ajar switch and (1) wire to a body ground anywhere along the frame.
I am sure this is how @ Bsthroop wired his setup”
If it is a NC system, and you are tapping into it, you need the new switch to create a loop. Running two wires will be necessary.
The rationale for this being:
The hood switch will continue to send a ground if it remains closed.
Having installed somewhere in the thousands of security or remote starter systems over the duration of my career, I have added my share of sensors and solenoids.
I believe a mag switch is the best option. For this. A good one is relatively inexpensive. Finding one that is rated for AND can stand up to the elements yet small enough is the trick.
I would avoid the popper installation. It takes a lot of force to open the latches. When installing aftermarket systems, you are left with few good options to connect to. The mechanical interface you create is nothing compared to what the OE will do. A failed door popper is less of an issue because you have door #2. If your tailgate popper fails, you have to get into the bed and then inside the tailgate.
The popper is possible. Probably relatively easy. I would caution against the reliability.
