Fordstanger
Took delivery yesterday, 47 PSI. Except for the one that had a screw in the tread, that one had 40. New tire being ordered by the dealer.
Don't know that they hand them out.Does anyone have a copy of the PDI sheet they could post. When mine comes in I'd like to check it myself. I would be interesting to see how my dealer did the PDI.
It's probably computer entered data but I was hoping someone had already found something on the internet. I spent an hour searching but found nothing specific to Ford trucks or Rangers..Don't know that they hand them out.
I agree with you. My tires are set properly and I still get the slight shimmy / shudder during low speed acceleration. 2,500 miles or so on the truck, and while it seems less noticeable (maybe I'm getting used to it?), it's still there.I don't think tire pressure is the true solution to the low speed shutter. I'm running 30 PSI all around and still get the vibration when doing medium pedal launches from a stop.
After driving mine for a day, I now understand what you are talking about - it is rather odd. Doesn't really bother me too much, but it would be great to know what is causing it. I don't remember feeling it when I test drove one, but maybe I didn't drive it enough.I agree with you. My tires are set properly and I still get the slight shimmy / shudder during low speed acceleration. 2,500 miles or so on the truck, and while it seems less noticeable (maybe I'm getting used to it?), it's still there.
I have noticed some transmission gear hunting or delay when coasting uphill. No more rough shifting since the TSB.I have one of the earlier builds that falls under the TSB and have been avoiding taking it into the dealer despite the low-speed shudder and rough shifting at times. Yesterday "part B" of the TSB finally happened; rough idle when cold. So I will be taking the truck in to get the TSB performed and wipe the transmission memory clean.
Has anyone noticed rough downshifts when coasting? This seems to happen the most when coasting up a hill towards a light or stop sign. Maybe it is because I am not used to a vehicle that uses transmission braking (if that's what it is) but it is a very noticeable bump when it drops gears. I am wondering if this is related to the TSB issue of rough upshifts and idling or if it is just the way the truck works.
All points considered, all of us got our trucks from a dealer, and all of those dealers 1. Washed it, 2. Filled the gas tank, and 3. Made sure they tried to sell a bunch of add-ons that they have a big margin on, they could at least do the simple thing of making sure the tire pressure is remotely close to correct before I drive it off the lot.Regarding over inflated tires... I have heard that the dealerships like to keep the tires over inflated so that if the vehicle sits on the lot for awhile it will have less of a chance of getting flat spots on the tires due to lack of being driven. Same as when the vehicles get transported for long periods of time - transcontinental rail cars, cargo ships to other countries.
Also, if the tires were at proper levels then the dealerships would have to keep going around to top them up as they slowly lose psi each month. If the dealership has over a hundred something cars and half of them have sat on the lot for a few months. That is a lot of tires to be checked on for proper inflation!
I’ve had several tanks of quality 91 through mine(all I run it, and it’s the highest costs e available locally), and still have the low speed shudder.I need to get mine in for the TSB for sure it absolutely has the issues that are being described in the TSB thread... That said, I could definitely attribute some of the shuddering under medium load to the ECU pulling timing from a knock sensor. I haven't had a data logger hooked up to test the theory, but that's what it feels like to me. I wonder if anyone running premium fuel notices this feeling at all?
I had the same feeling in my Focus which I did data log several times and it was during knock events running 87 that the engine felt like this.
I need to get the data logger on so that I can see what it's doing under these circumstances.
