SOLVED: Driver Side Frame 1/2 Lower, Shim Added to Rear Leaf Spring
Geoff
NYS
'19 Ranger 1943 Willys Jeep
Retired Engineer
Jason L
Mount Pleasant, SC
2019 Ranger XLT 302A
Most roads are pitched toward the right for water runoff. This was clearly cleverly designed by the engineers so you will ride flat while underway :)
Gavin stevens
Gavin
Arizona, USA
2019 Ranger FX4 Lariat
Heh, nice try... So, given that the frame/axle distance is different in the back by 1/2" what does that point at? The leaf springs ? What holds the axle in place off the frame ?
Gavin stevens
Gavin
Arizona, USA
Leafs or shocks, but its gotta be the leafs.. Cant they just replace them ?
Osage
Wade
Austin, TX
2019 Ranger Lariat FX4
Aside from asking a dealer to fix, has anyone actually brought this to Ford's attention. Curious.
Gavin stevens
Gavin
Arizona, USA
Dealership is shimming one side apparently... get it back tomorrow. Is this a viable fix? Can't they just replace the leafs ?.
Dennis Harvey
Northern Virginia
2019 Ford Ranger XLT FX4
Is this just the rear end, or is the front end off too? I plan to take a look at mine today. Thanks for all the info guys!
Update: mine seems to be sitting level.
Gavin stevens
Gavin
Arizona, USA
Got it back from dealership after 10 days.. they shimmed the left side springs
Still looks a bit off, but better. They said it’s not guaranteed to be perfect, but since mine was so visually leaning, they shimmed it under warranty
Gavin stevens
Gavin
Arizona, USA
I took the truck to a suspension shop.. Had them install a 2.5 front leveling kit. It looks pretty nice lifted, they said they tried to fix the lean. It still leans.. sigh..
mike
Hawaii
2019 Ranger Lariat Supercab, Nissan Rogue
Why is this so difficult to fix???
It's bizarre isnt it? Some have it and some don't so what is the difference that makes the difference. It's like the industry's dirty little secret. Ford, chevy, jeep, etc.. all have the issue. Blame it on the gas tank worked for a while I guess lol.
I have seen MANY threads on the Jeep forum talking about all the different things that might cause lean.. gas tanks, wrong springs, mismatched springs, etc... never a solution
Sounds like you just need to accept it..
Doc
Doc
Live oak fla
Mine has the left Gangsta’ lean also...
Johnpenn
Rockwood TN
2019 Ranger Lariat FX4, 2004 Corvette, 2005 Ranger Edge
Retired Quality and EHS Manager
With all the possible causes, is shimming the spring on one side really an acceptable fix? It seems to me that it's just a cheap way for the manufacturer to get by until the warranty period expires. I just hope mine is delivered level so I don't have to fight with Ford.
Rick - Saber
NC
Sport Ranger 4x4
I would have thought that they would put the gas tank on the passenger side to somewhat counter balance the weight of the driver.
Sure hope this gets sorted out.
PonyXpress
Sacramento CA
Tire pressure 45 psi all around
my reply is off topic, sorry....
huh, way over inflated - door sticker says tire pressure should be at 30 psi. Dealers are supposed to check that prior to delivery, but mine too was 45 all around. I lowered then to 30 and it feels a little sloppy to me, so I'm going with 35 now to try that. With so many wheel / tire size options, how can 30 psi be correct for all of us?
I think tire pressure would need to be pretty low to make a truck lean that much. I would guess that this is a suspension part defect. I do not agree that shimming it is the right answer. That is a weak work-around. Ford needs to find out what the root cause is and correct it with a recall.
