Driver side rear window molding...
OFC Ranger
Jack
ZR2
Ok you need to figure out what the heck is rubbing that when you get in and out.
That clearly shows a pattern.
Kind of like the seats on our patrol cars on the lower back side supports where our radios or other various holstered items eventually shred the cloth.
Not be rude, are you a big fella?
Joeiconic
2021 Ranger XLT
Looks like a about a two foot area where something is regularly wearing on that area. Unless you can prove it’s the door rubbing, which seems unlikely, that’s probably not a warranty fix.
VegasRanger
Las Vegas
2021 STX Crew Cab 4x4
Damper Salesman
Chris M
Surprise, AZ
2021 Ranger XLT Sport 4X4
Security Supervisor
It puts the lotion on the gasket.....
IT PUTS THE LOTION ON THE GASKET!!!!
OFC Ranger
Jack
ZR2
So here are the high wear areas on patrol car it really doesn't matter if you're fat or skinny it's pretty much going to be the same. The first two pictures showed the door seal area same as on your truck and the other area is where the gun holster is and then our backs
Now I could be incorrect but if you look at my door seall markings and yours the wear is similar enough that if I was a betting man you've rubbed it that way somehow
NickTheEnforcer
Anthony
Northern Illinois
Same issue on rear drivers side..mine was way worse when I bought it in '19. It was the first visit back for warranty work. been fine since then.
RedDakooter05
Illinois
2024 Nissan Frontier S 4x4
I'd probably try some silicone with an applicator (Such as this) if anything. The dealer "Techs" would likely screw it up more.
Peel it back, apply some silicone, and hold down til it dries in place.
JKocot
Montpelier, VA
2020 Ranger Lariat SCrew FX4, 2018 Explorer Sport
Senior Systems Engineer/Former Marine
Yep - same thing on mine. What are the odds? lol.
Noella
Noella
Mackey ON
2020 Ranger XLT SuperCrew 4x4 2.3l
I have a 2020 ford ranger XLT SuperCrew. The rubber molding around the windows on the inside/outside are starting to peel away from the my 2 front doors.
Does anyone have any issues like this? If so, how did you fix it? And have you taken it to a ford dealer to see about getting it repaired?
