Question about rear shock replacement
I've upgraded my rears to Bilstein 4600's, and I agree with the overall sentiment of this thread. However, I am planning to upgrade the front suspension as well- can't stand the wallowy front suspension, the truck just feels way out of balance with the super soft front end and firmer rear.
I am a little worried about that as well. I guess I'll just have the dealer do the front if it's bad enough.
I feel ya, I wanted to put in my new multi leaf rear sprigs today but the house AC decided to take a crap so that took precedence, 101 today, 107 tomorrow. Got the AC fixed ( start capacitor on the condenser ) so I'll try and get the springs hammered out tomorrow before the heat and then take a dip in the pool before returning to a well ACed house.
If you lost the starter cap on the unit I would suggest you also replace the starter relay. High current draws that kill the caps will also pit the contacts on the relay. This sets into motion the same situation reoccurring
Depending on the age of the unit they also have hard start aux caps that you add in to the circuit.
My central AC is pretty old. Learned a lot over the years to keep it humming along!
JesseS
Jesse
NorCal (Roseville)
Received my Eibach's today, will install this weekend after the 100º+ heat is over.
Well, got them on with little trouble, mainly just the top right nut is behind the bracket and its a very tight fit, ended up taping the nut in place (kept falling out of the tabs) after fishing it out from behind the bracket from dropping it twice. Used a small floor jack (motorcycle) to compress the bottom eyelet into place for the bolt, that was actually much easier than a ratchet strap. It was already mid-90º when I finished so will test it out on a 200 mile trip to family tomorrow.
Well Fedex tracking says my Eibachs should be waiting for me when I get home. Any helpful tips on install? I assume you mount the top end first.
Well somebody at Eibach screwed the pooch. This is what I received today. But I called and got great customer service and they are sending out the right ones ASAP. I was so hoping to get the new ones on tonight.
Colo_Ranger
Yup, and be ready to push hard... Its not that difficult, but you have to get under the shocks to push up. The guy who helped me said the bed of the truck lifted an inch before they started compressing.
Tom_C
Virginia, USA
System Admin, Retired
I swapped the rears only with Eibach pro truck 2.0 and it helped a lot. I bought them because at the time the bilstein 5100s were out of stock, and I don't know one is better than the other but from reading they are both about the same. Easy install in my driveway. Recommended.
I can tell the front is still a bit soft, but swapping the rears makes a huge difference and I can live with the fronts as is.
brroberts
Randy
Overbrook, KS
audio / semi retired
I found the Bilstien 4600’s enough on the rear. Don’t really mind the front, but some do. Very easy to compress the shock with a small ratchet strap and then just stick it in. The rears are a really easy job.
janitorjim
Plano, TX
Ford Ranger XLT 2021 302 pkg, FX2, Sport
ok maybe a stupid question but I hear about the ratchet strap to compress. Is this after you have the top bolted in and if so are you placing the hook of the ratchet in the bottom bolt hole of the shock then the other hook on the leaf spring (or frame) and then ratchet it down?
Tom_C
Virginia, USA
No, I wrapped the strap around the shock posts, and protected the body of the shock with a rag. Compressed the shock, and then put it in place and adjusted the strap so the holes lined up. Once bolted in I let the strap loose completely and pulled it out. Some people can compress the shock by hand, but I couldn't. The ratchet strap worked.
janitorjim
Plano, TX
ok that make sense. thanks
Hot Pepper Red Zeppelin
Earth
2019 Ranger XLT
Installing the Eibach rears this weekend and have some questions....
1 Does orientation matter? I've seen videos showing both ways.
2 Is dust boot necessary? Most videos they don't use it.
3 What is the torque for the bolts?
landiscarrier
Landis
Pocono Mtns Pa
2025 Ranger Raptor
Sales
Did anyone say YES yet?? LOL I went with Eibachs all the way around and a HUGE improvement.
GSD4EVR
NC Piedmont
2020 Ranger XL-STX 4WD
1) Some say yes, some say no. I have the Bilsteins and according to the manufacturer the bottle goes down and the piston goes up.
2) Not really. Depends on where you do most of your driving.
3) IIRC it is 55 ft-lb for the rears
