I just replaced the rears on my STX and couldn't be happier. Feels more planted, less boucing and body movement. I installed Eibach Pro truck shocks, well worth the investment. Have front Eobach Stage 2s waiting to go on.I have read many posts of people getting an improved ride and handling with aftermarket shocks. Is the improvement as noticeable on non-FX4 trucks? Is it worth it?
Good question, as I've posted the same question before. Short answer is yes.I have read many posts of people getting an improved ride and handling with aftermarket shocks. Is the improvement as noticeable on non-FX4 trucks? Is it worth it?
If I am not mistaken... if FX4 trucks have better shocks than regular 4x4 and 4x2, wouldn't aftermarket shocks show vast improvement over regular shocks since FX4 are better than regular 4x4, 4x2? Just wanted to be correct on the information if I am wrong... But, I had a regular 4x4 and JUST rear shocks improved my ride immensely. Less rear body roll, less body wiggle. Also, I feel it lessened the amount of back and forth swinging I had when I hydroplaned, only loss control back and forth for two swings then I was able to re-correct it. I want to go full suspension but keep the stock stance in the further, further future.I have read many posts of people getting an improved ride and handling with aftermarket shocks. Is the improvement as noticeable on non-FX4 trucks? Is it worth it?
It doesn't matter if it's a FX4 or non FX4. Replacing the shock and struts will make a huge improvement in the ride quality and handling. Ford screwed up the valving ratios for the dampers on the Ranger. They made the rebound damping way too soft. As a result after compressing the suspension rises too rapidly and over extends then compresses again returning to normal ride height and then rebounds again etc. This is what creates the rolling boat/bounce while driving. Aftermarket shocks/struts have muck better rebound valving thus slows the rebound stroke considerably and all but eliminates the boat/bounce experienced with the stock dampers. This is for both the FX and non FX equipped trucks.If I am not mistaken... if FX4 trucks have better shocks than regular 4x4 and 4x2, wouldn't aftermarket shocks show vast improvement over regular shocks since FX4 are better than regular 4x4, 4x2? Just wanted to be correct on the information if I am wrong... But, I had a regular 4x4 and JUST rear shocks improved my ride immensely. Less rear body roll, less body wiggle. Also, I feel it lessened the amount of back and forth swinging I had when I hydroplaned, only loss control back and forth for two swings then I was able to re-correct it. I want to go full suspension but keep the stock stance in the further, further future.
Thank you for clearing this up in a very very knowledgeable and insightful way Bret.It doesn't matter if it's a FX4 or non FX4. Replacing the shock and struts will make a huge improvement in the ride quality and handling. Ford screwed up the valving ratios for the dampers on the Ranger. They made the rebound damping way too soft. As a result after compressing the suspension rises too rapidly and over extends then compresses again returning to normal ride height and then compresses again. This is what creates the rolling boat/bounce while driving. Aftermarket shocks/struts have muck better rebound valving thus slows the rebound stroke considerably and all but eliminates the boat/bounce experienced with the stock dampers. This is for both the FX and non FX equipped trucks.
I feel ya, I wanted to put in my new multi leaf rear sprigs today but the house AC decided to take a crap so that took precedence, 101 today, 107 tomorrow. Got the AC fixed ( start capacitor on the condenser ) so I'll try and get the springs hammered out tomorrow before the heat and then take a dip in the pool before returning to a well ACed house.Received my Eibach's today, will install this weekend after the 100Âş+ heat is over.
