Oil Change - DIY
SeattleRanger
Jay
Seattle
2020 Lariat, 2003 XLT Ford Ranger
Beekeeper
Has anyone changed the oil on their Ranger themselves? I watched a YouTube video and he was pulling off skid plates and plastics to get into things like the drain plug and filter.
Is that really required or is there a different method you used?
Thanks!
jsphlynch
2019 Ford Ranger XL
Do all my oil changes myself. On the 4x4, the factory skid plate needs to be removed to access the drain plug, but it's just 4 bolts and it pops right out. Some folks have added a fumoto valve or similar to avoid this step. The filter is accessed through the driver-side wheel well, and requires removing some of the pins holding the flap in place behind the wheel. This is a little annoying, but quick and not difficult. Contrary to some early reports, removing the wheel is completely unnecessary.
SeattleRanger
SeattleRanger
Jay
Seattle
Beekeeper
Ok, great! Thanks for the confirmation. I have no problem doing all that, I just didn't want to attempt if there was a better way (like not removing a tire).
I appreciate the response
Done one change already (my first) and coming up on another change within weeks. I went with Fumoto drain valve install during first change. So from this point on just attach drain hose and open the valve. No more skid plate removal or skinned knuckles
What Joe said, no need to remove wheel for access to filter. Just cock steering all the way to make getting in to it easier.
Now the fun part. Some on here including me found the factory seating of filter was excessive. Took a cup socket on end of filter with some serious muscle to get it off. So have the right tools for this reason. Otherwise it’s as easy as it gets!
Just change mine for the fourth time yesterday, 20K. I have a Valvomax drain valve, no removing skid plate, no jacking up truck, no drips on driveway. Yes the flap in the wheel well is the biggest pain. Going to get different retainers that are easier to remove. Also get yourself an over end expandable filter wrench and a long extention to remove the filter, cheap at Harbor Freight. Oh and don't forget to move your catch pan over behind the front wheel to catch the oil from the filter.
Have fun, after putting the valve on the first time it's a peice of cake.
Is this https://tinyurl.com/yhq4q5um the valve you are talking about? The "Quick Twist Valve with Stainless Drain Tube Knob".
That's the one. I like how it uses a check valve type of shut off instead of a ball valve and lever setup like the Fumoto. Being stainless and US made doesn't hurt either.
SeattleRanger
SeattleRanger
Jay
Seattle
Beekeeper
Awesome, thanks. Ordering today!
gasmanjohn
Itasca, IL
'19 XLT FX4, '19 Beetle Final Edition
Gas leak inspector
Make sure you're on level ground too, or else the filter will drain right onto the front axle and go everywhere. Front wheels on ramps= bad idea.
SeattleRanger
SeattleRanger
Jay
Seattle
Beekeeper
Thanks man. Good to know as I’d planned on ramps but won’t do that.
Langwilliams
Langley
Lorain, Ohio
the fumoto valve with the nipple to attach a hose to. I just tuck it above the skid plate, then point it into a disposal jug when draining. I had a hard time getting the filter off too an ended up buying one of these. It's handy because not all filters are the right diameter for the end cap wrenches. I've used a wix and a moble one filter on my truck an all were different.
They’re the same diameter filter. It’s the number of flats on them that’s different. 14 flats at 73 mm is fomoco filter and mobile 1. 15 flats at 73 mm is wix. Yup I got both sizes now! That was a head scratcher for sure!
Oh, I did mine on ramps for what it’s worth first change and no issues or mess.
Langwilliams
Langley
Lorain, Ohio
That 3 jaw filter wrench is a life saver for Harley filters. I bought the HD tool but it only works on actual HD filters. I have used wix an a few other that make long life motorcycle filters. It works well for reaching straight in like you have to on the ranger. My friends have borrowed it too. I've gotten my 6 bucks worth out of it.
The Fumoto # is F-137N. Been using their stuff for years.
I do like the Valvo Max, but the Fumoto is self contained...you don't need the separate attachment.
Bottom line is there both good products and make changing oil super easy.
