FORScan Crowdsourced Wiki
I have yet to run across a reason I would want to disable traction control even temporarily, let alone full time.
But yet you hate hitting the traction control button?
Replying to wrong poster. @E Monty is the one who doesn't like hitting the button. I agree why does he want to disabling traction control all the time.
Geoff
NYS
'19 Ranger 1943 Willys Jeep
Retired Engineer
Geoff
NYS
Retired Engineer
I recently drove 1500 highway miles and along the way I had to drive thru a couple of inches of slush and/or snow. In some areas I engaged 4WD but for the most part Traction Control worked really well and kept the vehicle running true and straight. Without traction control I would have had to use 4WD much more often or risk losing control (unless I slowed way down). I found it to be a definite asset (altho there may be a reason to turn it off I have yet to come across a situation that calls for that).
Geoff
NYS
Retired Engineer
daniel3507
Oklahoma
2019 Ranger XLT Sport 4x4
I would be more worried about insurance finding out a safety feature was permanently disabled. They can be a little snake like as is so I would hate to give them more ammo.
t4thfavor
Chance
I just got stuck in 20" of powder with 1" of crusty ice underneath. When I disable TCS, I could move, when it was enabled, I was fully stationary.
Not a case for full-time disable, but at least a case for where it's usefull to be able to disable.
Geoff
NYS
Retired Engineer
humm....Interesting, thanks for that info.
A couple of questions if you don't mind...
Does your vehicle have a locking rear end?
Was it in 4WD?
Gizmokid2005
GA
gizmokid2005.com
SQL Developer
Was it in 4WD?
I've done the same, a few times. LSD rear end and 4wd. In icy/snowy situations often times you need the wheels to keep spinning to burn through the covering of slick materials to where you can get traction. A bit similar to a muddy situation, and within reason, how you want it to run in Sand as well.
Geoff
NYS
Retired Engineer
Yeah, thank makes sense.....I haven't had my truck in that situation but yeah, I agree with you there. Good thing for the switch! lol
t4thfavor
Chance
Was it in 4WD?
I have an FX4, I tried trail control, Grass/Gravel/Snow mode, locked and unlocked rear end. Nothing helped until I turned off TCS.
Davejb
New Hampshire
2020 Ranger XL STX
Was it in 4WD?
This isn't anything new or a Ford thing, I did the same with my 2011 Charger in the snow, in order to rock it or get wheel spin to get moving TC needed to be turned off.
jzinckgra
Maine
2020 Ranger Lariat
This may have already been asked, but is it possible to allow for bringing up the 15 automated text replies when you want to reply to someone without having to pull over? I can't believe the number of nannys Ford has. My Honda would allow you to reply while driving. Not actually typing out a text, but it had four options: yes, no, I'm driving, I'll call later. If I have to pull over, why would I use the sync screen vs my phone? stupid
t4thfavor
Chance
"OK Google, send a text to my dad"
"Hey Siri, send a text to my dad"
Problem solved mostly.
I think the sync button will do the same, though it's not as good as the two other options.
jzinckgra
Maine
2020 Ranger Lariat
I don't use android auto, mostly because i'd rather not have to attach my usb cord to my phone everytime I drive the truck. Sounds pathetic, but the few times I need to send an auto reply, I'd rather do it through sync. So can it be programmed or not? thanks.
