FORScan Crowdsourced Wiki
t4thfavor
Chance
I don't use android auto, mostly because i'd rather not have to attach my usb cord to my phone everytime I drive the truck. Sounds pathetic, but the few times I need to send an auto reply, I'd rather do it through sync. So can it be programmed or not? thanks.
No, the nanny state wins. Plus you don't need to use Android Auto to do what I said above. Your phone can do it no problem without any physical connection to the truck. (as long as it's newer than 7 years)
jblc
JB
USA
2021 XLT FX2 supercab
I think that one is only changed by a hex code edit of 720-01-02. At least that is how I had to disable it. Besure to backup the module and/or take screen shots of the code and give it a try, its just as easy.
Does anyone know if 720-01-02 (xxxx x2xx) means
xxxx x2xx xxxx
or
xxxx xxxx x2xx
(There's a missing xxxx in the instructions)
xxxx x2xx xxxx
or
xxxx xxxx x2xx
It is as it is shown, that particular PID only has 2 quads not 3
jblc
JB
USA
Does anyone know how to disable parking and brake lights when the vehicle is unlocked?
Dark Mode is activated (along with Silent Mode Menu), but they still turn on.
I read through all the pages, but didn't explicitly see this...
I see, thanks :)
Some other codes showed full 4 hex digits to represent (say) other small values like 01, so it was ambiguous...
If you go into the ad-builts you will see the codes vary in length. Always in groups of 2 and the last pair is always a checksum.
jblc
JB
USA
1) FYI to all, these settings don't seem to have any effect (2021 XLT):
- Fuel pump prime when door opened = Disabled. Pump still primes.
- Mirrors down on reverse. This is expected...people surmised there's a missing module, so I tried it just in case.
2) Does anyone know how to disable parking and brake lights when the vehicle is unlocked?
1. Yes, several of the settings don't work on our Rangers. Some of the memu features cross over to the F150s.
Our Rangers don't have door modules so things like mirror tilt and auto windows on lock don't work. I quess I'm not sure about the pump priming or why you would want to disable it.
2. Dumb question did you go into the menu and turn silent mode on?
No offense, just have to ask.
jblc
JB
USA
...did you go into the menu and turn silent mode on
Thanks for the info.
And no worries at all :) , please sanity check my process, as it's very possible I forgot a setting :D
Here's what I did:
Dark Mode: Enable
Silent Mode Menu: Enable
Is there a separate Silent Mode On setting?
I spend a fair bit of time working on the vehicle, or camping out, opening and closing doors frequently. Priming on key insertion is better for my needs.
If it primes needlessly dozens of times, it might waste fuel (<-- total conjecture, not sure) but at the least, wastes battery power.
Here's what I did:
Dark Mode: Enable
You go into you menus on your dash display using the left steering wheel switches. If I remember right it is under the settings menu. I'll check when I get in my truck tomorrow.
jblc
JB
USA
All,
Also, I see something odd but good: Traffic Sign Recognition and Auto Start/Stop switching, directly in the Sync 3 menu!
My 2021 didn't have these menus until i wrote settings in FORScan:
including Police Dark Car Mode in ACM (different from Dark Car mode in BCM). Suddenly a large amount of new Settings menus show up on Sync 3. This includes traffic sign recognition, etc.
There are 3 Sync screens full of settings, instead of 2 screens of settings.
There are many greyed out options, due to unsupported features.
Has anyone seen this before?
It seems promising, and I'll test them out in any case.
HDA
Hector
2021 Ford Ranger XLT Shadow Black
Travel X-ray Tech
Unable to connect with 2021 XLT ranger. It says its unable to identify my vehicle.
Contact the people at Forscan as they can give you the software needed to connect.
WLFPIR8
Ethan
Central Ohio
whor.us
2019 Ranger Lariat FX4/Sport in Saber Orange
Systems engineer by day, maker and multimedia guru by night.
They need to update for each new model. I'd assume that will happen soon. I'd check on their site.
HDA
Hector
Travel X-ray Tech
I got it working. Changed a few settings and now my speed is limited to 80? What’s that about?
