- Joined
- Aug 24, 2022
- Threads
- 28
- Messages
- 4,534
- Reaction score
- 8,634
- Location
- Midwest - KS
- Vehicle(s)
- 2022 Ranger Lariat-Super Crew, Cactus Gray
- Occupation
- Aircraft Tech
I am wondering, but it goes against the service manual that drives it home to only perform BMS reset after battery change - which I understand
But the charging algorithm is controlled by the PCM and BCM and is using Time Installed as it's reference (age of battery)
I wonder if doing a BMS reset say every oil change would help in extending the life of the battery and resolve most of the issues owners are experiencing.
I am understanding that the older the battery is (Time Installed) the system is actually lowering its charging phases due to its reference to the time installed (age)
I am only pondering thought here, I have no back up documentation to my theory, I don't think the system actually monitors battery health (ability to hold charge)
If you think about it, you are basically doing the same thing when you are leaving on battery tender etc. you are forcing a new battery charge bypassing the BMS (current-Charging Phase) it is in.
I will dig deep on this subject, but unfortunately there is no real in-depth explanation on how this system works, only vague descriptions. But I'm assuming it proprietary info, or it would be easy to find. The BCM and PCM have the internal programming (set-points) voltages but what are they?
Any why does the manual make it so IMPORTANT, not to perform BMS reset unless battery is replaced?
What harm would it do to perform a BMS reset and refresh the charging phases (cycle) on an older aged battery?
The way I understand it, you would be telling the system, I have a new battery installed (actually) faking it and forcing the system to charge the battery like new, thus by-passing the need for battery tenders
I am also thinking the BMS system operates similar to the OIL Life Reset, it's calcinated by the Time since reset and other factors (miles etc)
If anyone disagrees with this thought - please post
Just A Thought
Just A Thought
