Sync Map update with help of Ford Customer Service
Jerry Caldwell
Jerry
Granbury, TX
Ranger Lariat
Retired Architect
Check if anything shows up in the IVSU Versions menu. You'll look for the 14G421 and 14G422 items. Did you power cycle after running the map delete utility? I've personally never used that one, so it's not clear to me if it needs that reset first or not.
Yes I power cycled after running the delete utility. The instructions I received specifically said to turn the ignition off and wait for everything to power down before running the install. I am not familiar with the IVSU Versions menu.
UofMEngineer
So, push and hold both seek forward buttons (steering wheel + IP panel) for ~10 seconds. End the speaker walk around. Select the APIM item, then IVSU Versions. It'll show you a list of what all is installed on the unit.
Jerry Caldwell
Jerry
Granbury, TX
Ranger Lariat
Retired Architect
Forgive me for my acronym ignorance, but what is IP panel? I push both up buttons on the steering wheel but get no response. What am I missing? Never mind, just found it.
UofMEngineer
Looks like it's all there. One thing you can try is running a master reset in case it had some problem mounting the new images. You also see the 4U5T-14G424-CB listed as well, correct?
Jerry Caldwell
Jerry
Granbury, TX
Ranger Lariat
Retired Architect
Not seeing the 4U5T-14G424-CB when it would let me scroll down. Doesn’t let me do that now.
Jerry Caldwell
Jerry
Granbury, TX
Ranger Lariat
Retired Architect
I just checked my thumb drive and see 4U5T-14G424-CB.TAR.GZ. All in caps if that matters.
Also tried the master reset with no luck.
UofMEngineer
Last thing I can think of to try, short of running the entire spiel again is... save a backup copy of the autoinstall.lst file on the map update drive. Then, edit the one still on the drive (you can use Notepad or similar) to contain:
[SYNCGen3.0_ALL]
Item1 = Map-License
Open1 = SyncMyRide\4U5T-14G424-CB.tar.gz
Options = AutoInstall
Just in case, for whatever reason, there was some glitch with updating the license file. The map and voice data is there, so the license *should* be there. Won't hurt to try.
[SYNCGen3.0_ALL]
Item1 = Map-License
Wouldn't the filenames be case sensitive? Isn't the OS some linux derivative?
Case sensitivity gets me every time.....
UofMEngineer
Never tried it that i can recall. Wouldn't surprise me though. Usually I'll drop the .gz or something by mistake in a copy and paste. You'd see a LST error if that was the case to indicate it can't find an expected file.
Jerry Caldwell
Jerry
Granbury, TX
Ranger Lariat
Retired Architect
[SYNCGen3.0_ALL]
Item1 = Map-License
just opened it in notes and it appears to be encrypted (looks Chinese). Guess I will do the install process again just for fun.
UofMEngineer
Did you open it with notepad? It's possible it somehow got corrupted if it's nonsense characters.
UofMEngineer
Sorry, yes Notepad. Wouldn’t it have caused an error during install if it was corrupted?
Yes, it would have, or it never would have run. I've had the same happen to me before but never figured out where/how the file got corrupted.
Jerry Caldwell
Jerry
Granbury, TX
Ranger Lariat
Retired Architect
I had more than one copy of that key file and all of them looked the same when opened with notepad. Is there any reason I shouldn’t do the install again? It is completely screwed up right now so I don’t guess it could not get any worse.
UofMEngineer
Only reason would be the added annoyance of having to re-run the delete tool and the map update again.
