Sync 3 Map Update Available - NA 2.23
Minuteman3
Ken
Tacoma, WA
2022 Lincoln Corsair GT, 2022 Ford F-150 XLT
Retired USAF, semi-pro photographer
Got a notification that the "new" map version, NA2.23, is available for Sync 3. I have two vehicles, both with Sync 3, a '19 Ranger and a '22 Corsair GT, and the maps were available for each. I started with the Ranger as a couple of years ago I purchased the 5-year version. Sure enough, the download was "no charge" and the download went without a hitch.
Install in both vehicles was easy, if time consuming. Driving around in the Corsair took about an hour (at USB3 speeds), but my '19 Ranger is still USB 1/2 and took almost 3 hours to install!
The protocol is to start the install, and leave the USB stick installed until you see the "You can now remove the USB device ... " notification pop up. There are a couple of intermediate segments that pop up a "installation is complete" notification, and the system reboots, but don't be fooled. It's not actually "done" until you get the "OK to remove the USB device ... " notification!! Other bummer is if you shutdown the car and interrupt the install, it has to start up again from the beginning ... so plan on a nice long drive!!
Other than that ... everything went well and both now show NA 2.23 as the current map version.
Ken
PltFX4
Richard
Minneapolis, MN
2019 Ranger Lariat FX4
General question and a specific one to @Minuteman3 :
Can one update the maps WITHOUT updating the Sync version?? So, if your on a lower version of Sync (latest is 3.4.23188) and just want the maps, can you do that?? In either case, I wonder what the processing time for the Sync update vs maps... maps are of course large (1+GB per region) but updating the app might take actually more processing power than transferring the maps and decompressing them.
I was already on 3.4.23188 but the "package" I downloaded from CyanLabs had the app and maps and appeared to "reinstall" app during the update process for a total time of 35 to 40 minutes.
@Minuteman3 :
Did you update both maps and app or just maps
Is/was your USB drive ver 3 capable? (assuming you used the same one for both cars, I guess the answer is a Yes)
Do we know officially that Ranger is only USB ver 1/2 capable?? or is the processor in the head unit the bottleneck??
Edit:
Found this on the Ford Sync website:
SYNC 3
To update SYNC 3, the USB must be:
  • Either USB Version 2.0 or 3.0.
  • 8GB or 32GB.
  • Formatted to ExFAT.
  • Without a password.
  • Completely empty.
Note: If your vehicle is equipped with SYNC 3 with Navigation, you can enable automatic updates via Wi-Fi.
( What are the flash drive requirements when performing a sync update )
Minuteman3
Minuteman3
Ken
Tacoma, WA
I am already sitting on Sync 3.4.23188, so I only installed the maps (NA 2.23)
Clearly, the '19 Ranger is not USB 3!! I believe the head units themselves are probably similar (since they are both running 23188) but in any case the only real difference is the connections - USB 2 vs 3.
I can't speak to the Cyanlabs "package" or their install system. I only use the Ford direct sources for my updates and downloads.
Ken
Ohwell
Minnesota
2023 Ford Ranger XLT FX4
I updated using Fords download, no problems. If it does reinstall the sync update, maybe it includes other undisclosed fixes. Whatever happened with that Wi-Fi driver vulnerability we had.
