SYNC 3 UPDATES 2025?
PltFX4
Richard
Minneapolis, MN
2019 Ranger Lariat FX4
Ok I was idling with engine running during my Map update, 2x I received a message on the screen system rebooting, and then after reboot a message was displayed to cycle ignition off and restart - (exact wording?) to continue with update.
I wish I would have snapped a pic of the message.
Note: The engine never auto shutdown, I interacted and manually performed the action.
Sync is looking for a complete power drop at those points.
So even with engine not running and using a (charger) you will still need to cycle the key.
This is my 4th map update, I recall all of them being the same - cycle
Edit: I think the wording is "Key Cycle Required"
Ok, I did not get the cycle the key message. Were you upgrading Sync or just the maps?? I was already on Sync 3.4.21388, so guessing a key cycle was not needed for just the maps. ¯\_(ツ)_/¯
RangerBill
There is essentially no difference between doing the updates with the engine running or using a charger in accessory mode, except you are not idling or driving (using fuel). If you are driving while doing the update, you don't have to disable auto stop, but if idling in the driveway or in accessory mode, you have to disable auto stop or the engine will stop or the accessory mode drops out. I have done 3 or 4 Sync and or map updates using this method. The software update prompts are the same using this method.
only map update, so it appears to be (only-if required), the only difference I guess would be I was (Idling in the garage) and it appears you were driving, all of my updates I have done have been done via USB both for (Sync & Map) - NEVER auto update or OTA and turned it off within the first month of ownership.
PltFX4
Richard
Minneapolis, MN
"all of my updates I have done have been done via USB both for (Sync & Map) - NEVER auto update or OTA and turned it off within the first month of ownership." LOL... yep, same here
I guess all that matters is - you get the final - You may now remove your USB device, that was my main objective of pointing out, and to not be misled by the (update complete) message alone, as if you let it sit - it will change over to system updating again.
No matter how it gets to that point, system reboots or cycle ignition - the final message is the most important - since we cannot visually see a progress bar.
Now the message i was getting (Cycle Ignition) may be tied to (Auto Engine Off) - IPC, if I recall when selected is 30-Minutes - Not to be confused with (Remote Start or ASS settings)
When I am doing anything - that requires engine running at idle for long periods, I either select it off or just hit the button to (continue) when the message pops up on the (IPC) engine is about to shut-down.
Since modules crosstalk, the Sync update process, may be automatically popping the message up to match the (IPC-Configured) selection since I had it selected (Auto Eng Off)
If I had it selected (Off) I may not have received the Sync (Cycle Ignition) messages and only saw the automatic reboots.
IDK, as I said - the most important is the message - To Remove the USB as all of the updating process is hidden from view.
Dean
Gold Sponsor
Dean
2019 Ranger XLT, 1988 Merkur Scorpio, 1959 Austin Healey Sprite
Embedded SW Engineer
I am already impressed with the long term commitment of Sync and Android Auto software.
Have you ever wondered "How long will it last?" Will it still all work when my truck is 15 years old?
I have a 2018 Google Pixel 3 cell phone and Sync is latest. I can't believe that it all still works flawlessly. How long will this last? Granted, it is time for me to get a new cell phone :)
Unless you you have worked in software development I don't think you can appreciated the long term commitments of interoperability that is involved here.
Racket
Here and There
2019 Lariat Supercrew 2WD
Transient
I used Cyan Labs way back when to get the 'latest' Sync versions but worried this would somehow keep official Ford updates from happening. Just happened to check today and it seems all is well.
The 'updates' screen says I'm up to date, and I'm connected to the home wifi.
There is actually an update- released in May, Ford does not show it yet - but Cyan Labs does
I just checked on Ford site and mine says Up To date also.
Here
XLT
I’ve never performed a Sync update since I bought my 2019 new. I have the 300A package (4” screen) on my XLT. My truck runs fine, phone connects, handsfree works, iPhone nav directions come through my speakers, app works as it should.
I don’t see what I might be missing out on - maybe this matters more if you have the electronics package with a touchscreen?
Superspirit
earth
22 ranger
I went and checked for updates by my Vin. Sync said up to date checked the map updates 1 available but I have to purchase. The option to download for free is gone my truck is a 22 my. So guess they don't support past 3/36. And that sucks as nav was a $1k option.
I don't like the maps on the truck as they don't update fast enough. In areas like Phoenix where there's so much development it can't keep up and was constantly sending me to dead ends then saying "walk on foot from here". o_O Apple Maps updates way faster and has never left me stranded and a big bonus is it's free. lol
Superspirit
earth
22 ranger
Apple maps don't help me, I'm an android user. I can use Google maps but I prefer the factory nav as I like it on the screen. And I'm not a fan of android auto just don't like it. So I'm stuck with my outdated maps and check the phone when a problem arises. Cuz I'm too cheap to pay $109 for a map update. Shame on Ford. But this isn't as bad as the 26 explorer ST. After 8 years you have to repurchase the connectivity package to keep using the features so it will get traded off at 6 years old for a technology less vehicle. The world has gone MAD MAD I tell ya.😁😁😁
Living The Dream
Try Waze.
Works great on Android and I prefer it to Google Maps or Apple Maps.
Showing you where the Popo and speed cameras are located is a nice bonus.
RangerBill
You can use your phone's WIFI hotspot to keep using the Explorer's connectivity features without paying for the connectivity package after it expires.
