- Joined
- Aug 24, 2022
- Threads
- 28
- Messages
- 4,587
- Reaction score
- 8,763
- Location
- Midwest - KS
- Vehicle(s)
- 2022 Ranger Lariat-Super Crew, Cactus Gray
- Occupation
- Aircraft Tech
If moving the passenger door by hand and still getting ambient air, the only thing that would cause it would be that the door is not fully closed and blocking the heater core airflow.What a wild ride. Just read the whole thread. Thanks for everyone's input.
I think my symptoms are slightly different than others?
Outermost driver side vent blows ice cold when set to Lo.
Passenger only blows ~ambient when set to low.
Both blow full hot when temp set high. Both actuators move freely, no clicking.
I removed the passenger side actuator and cycled the blend door by hand. Seems to move freely. Passenger side still blows ambient with the blend door held firmly in the cold position by hand.
Not sure where to go from here...
So a false feel of the stop as you manually move it or piece of the door broken off or a piece of the foam seal or debris is stopping the door from fully closing.
The actuator is not popping or clicking as it has recalibrated itself to learn the new (LO) position as it’s stop - if you have debris stopping the door from fully closing.
This is where an actual visual video on operation will help, as I can only go by pics and description. This is what quangdog can possibly supply after he gets his back in working condition using his old broken unit as a reference.
I am curious if one could get access to the floor duct outlets on the HVAC box and use a boroscope camera to actually see the internal movement of the door
