Screaming tailgate damper
Living The Dream
Figarou
FourMoreG
Geo
Hudson Valley NY
2021 Ranger 4x4 Lariat 501A
Driver
If no longer a Happy Camper
with your damper,
because for attention,
It does clamor ?
You could always pamper her,
by adding a lightly greased chamfer to her.
But, doing so,
may loose manufacturers support
after you tamper with her.
Just don’t loose your temper with the damn damper.
It would be nice if there is a solution section in this forum so new members can find it quickly.
Like a search bar? :shock:
The only problem is if you put damper in the search bar there's so many results it would take weeks to find what you're looking for. ?
Figarou
That's why I suggested a solution section. Or maybe pin threads that has a solution up top.
THLONE
Thom
Tucson,AZ
internet wise guy
When the lift struts that came with my shell ARE went bad the factory warranty replaced them. The installer said do not use wd 40 or window cleaner on the struts ( I dont) cause the seals dont like it. Since damper people are always messing up and doing things uneeded with everything, that is the problem. Also when using a damped tailgate the warning should have been plug your ears while waiting for your tailgate to slowly lower. I know it is hard to hold down your skirt when plugging your ears. So, damper people need ear protectors when watching the tailgate slowly go down, also it wouldnt be a bad idea to wear eye protection too. Maybe a warning horn to alert unsuspecting people that you are opening your tailgate. :crackup:
Figarou
Chris M
Surprise, AZ
2021 Ranger XLT Sport 4X4
Security Supervisor
Living The Dream
Don’t those without a dampner scream when lowering the tailgate anyways? No matter the temp?
That's the cheers from the throngs of single women wanting to know if the owner of that truck is available.
svgrdr
Elton
Maine
2021 Ford Ranger XLT
It seems below 30F my damper screams and is very slow lowering. It’s ok going up but man it sure screams going down.
Above 30 no problem???
WTH… no I’m not picking on Dave.
Mine is exactly the same in cold weather. It was 9F out this morning when I went to work and I needed to put some supplies in the bed, and my damper squealed when it went down
The poor kid standing under the tailgate screams pretty good...then dad screams, after mom wacks him over the head for dropping it on junior... ?
